DTC 16487 -- Bad MAF or wiring harness?
Audiworld Sponsor
Found the following DTC:
16487 - MAF Sensor (G70): Signal too High
35-10 - - - Intermittent
Search seems to indicate either a bad MAF or problems with the wiring harness connected to the MAF. Anyone have any input?
Thanks,
-Dave Pramanik
Thanks,
-Dave Pramanik
Depends
If you are chipped you should be seeing like 250 g/s +/-
Also when you plot the vag data you should see the MAF value climbing steady with the RPM value
I have seen it appear choppy (looks like a staircase on a line graph)
Also, FWIW probably isn't the wiring harness though you could check it out. Usually the car will throw a short to ground dtc for sensors it can't detect.
hmm
First and formeost your car is faster than mine lol
Depending on the mods you have you probably shouldn't be seeing over 270 on K03's (unless the weather is real cold where you're at)
What kind of mods do you have ?
snowman '92 100
12v V6 Discussion
03-01-2004 09:28 PM
BlownS4
16
11-27-2003 02:42 PM
Mark.core
10
06-10-2003 07:14 AM
MyKey
06-06-2002 01:58 PM
