Engine Mounts
Engine Mounts
All, I read the 'tech article' on replacing the motor mounts for my S4, but I don't see how it's possible. I realize it's not 'easy', but there is no way I could get my 1/4" ratchet in there with a socket on it. I'm not a mechanical wizard, but I can hold my own. I also had a buddy of mine who is very mechanically inclined take a look at it and he had no good advice either. Does anyone know if the tech article was written for a manual VS a tip? Mine is a tip. Maybe there is a difference there?
Both of my engine mounts were sheared off in a frontal collision so I'm working on both sides. The passenger side actually seems a little more friendly. The driver side is ridiculous so I'm going after it first.
My current plan is to make a custom wrench, drop the side of the engine slightly and cross my fingers. Does anyone have any other suggestions?
Best regards,
Bob
Best regards,
Bob
All,
I took all of the suggestions that I could find online and still no luck. I bought the 'stubby' flex ratchet wrench, I bought the standard 13mm (12 and 6 point wrenches...I broke mine during this project so I needed these any way) and I bought the 13mm 'offset' wrench. There is no way in hell to get these bolts loose. It seems as though the tech article on this topic must be dealing with a manual transmission. Otherwise the article makes no sense. I can get my finger on both of the upper engine mount bolts, but there is no way to get a wrench in there.
I would really appreciate any input. It seems that the old crowd that used to be here has moved on and maybe no one has dealt with this?
Bob
Bob
Post your question over on Quattroworld and Audizine. My experience has been that those are the two most active forums for the B5 S4 model, you may have better luck finding someone there that can answer your question.
All,
Bob
Bob
M3Armand
02-08-2009 06:11 AM
Double Barrel (Karl)
Florida Discussion
11-28-2006 02:42 AM
19885ktqcd in Wa. st
01-27-2004 10:57 AM
sbellan
02-03-2003 07:56 PM
