Fit Issues for RS4 Rep's 18x8.5 et35 w/ 235/40/18 tires? Xpost from 5/26/05
Yes I have STFA & I could not find a definitive answer.
Yes 18x8.5 might fit but they typically where not RS4 reps's (mostly BBS rims). 2nd I want to run 235's on the 8.5" rim since that is the optimal size for the rim.
I have no suspension mods & probably wouldn't be lowering her at a later date.
<img src="http://oewheels.net/oe-audi-rs4-g-1.jpg"><ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7976449 481&sspagename=STRK%3AMEFGWA%3AIT">Ebay Item</a></li></ul>
Based on the info presented, you should have no problems. A few other things..
-If you fender/wheel liner is not modded, ride height: 25.75" or higher, should be no rub.
-If lower, you'll most likely need to modify your fender/wheel liner. Then you'll be fine until about 24.75". If lower, nothing will save you from rubbing. :-P
Planning to get rs4 reps 18x8.5 30 offset will I run into any rubbing issues with 235 40 18 tires or
S4ptld
12
04-21-2008 06:06 PM
LaserRed_OC
03-29-2005 05:36 AM
Mr.Debo'sS4
13
05-17-2004 12:19 PM
Žob
12-10-2001 03:03 PM
PiotrC70
Wheels & Tires Discussion
05-28-2001 03:03 PM
