Fitment on Autospeed DPs??? Any experiences to share?
Thanks! Additional questions .....
Did you have them splice-in additional length to the senson wire or just cut-off the zip ties? If you cut the zip ties, can the wires be easily routed so there is no contact with pipes?
What are your thoughts on using these with stock K03s and stock cat back? I will replace the catback within a few months but may never go to K04s. Is it worth it with K03s? Too big for K03s - boost spike problem?
Thanks for the help !!!
I belive that Mark from AutoSpeed run them with stock exhaust for a while. No probs.
But if you are looking at DP's, then why don't you throw in the AutoSpeed exhaust into the mix?
I can give you a small discount if you buy both at the same time.
BTW, the fit is perfect on my install. And the match to ASP Tru-Dual225 is perfect as well. If you want to hear it... just follow the banner in my signature.
Tomasz
Tomasz
canyoncarver2
12
02-28-2007 11:46 AM
Andrew C.
10-31-2005 08:27 AM
KOpork
10
04-04-2005 02:34 PM
3Scanner
9
03-10-2005 05:16 AM
