flashing *check engine light*...
i was driving this morning at 60mph in a 5th gear, then i shifted to 6th and i felt slight vibration and then my check engine light went on for few seconds and was then flashed few times, after that i just went off. so i pulled over to see wtf is going on ,check the engine nothing was visual wrong.
AudiWorld Expert
The last time that happened to me...
I shot out a spark plug out of my head and damaged the coil:
<img src="http://ctny.audiworld.com/mark/s4/maintenance/stripped_head/dsc02958.jpg">
which resulted in me needing a new head:
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03084.jpg">
Actually, the last time it happend was on the Golf, and it was just a bad coil. Swap two coilpacks and see if the problem follows the coilpack. If it does, replace that coilpack. If it doesn't, replace all plugs. replace all plugs either way.
Anthony Maggiore
A4 (B8 Platform) Discussion
12
01-15-2019 05:27 AM
