Help with trouble code
This is the code I am pulling:
18010 power supply terminal 30 voltage too low
P1602 35-10 Intermittent
I clean both battery terminals and I still pull the code. What could be the problem?
Just guessing, but maybe a loose connection at the fuse box - terminal 30 are the unswitched power
taps under the dash near the main fuse box. Check all the wiring to see if something is obviously loose. Hopefully its something simple like that.
2001s4loored
02-09-2008 12:10 PM
TwinTurboTerror
9
07-11-2006 04:05 AM
boehm781
VAG-COM Discussion
08-05-2005 01:19 PM
