How does this O2 Voltage (Engine -> Measuring Block 031) Log look?
Just did a half-throttle 1-3 gear run. Ran a few different logs, but did this block 031 log of the O2 sensor voltages at the advice of a few of you after posting about my MBC install. I'm not sure what I'm looking at here, so maybe you can tell me if everything looks ok. Thanks.
<img src="http://www.personal.psu.edu/users/b/n/bnl107/O2%20Log.gif">
I don't know what you want to hear from us. At part throttle, the car will be at stoich.
That is why we have long term fuel trims, so the ECU can correct fueling at idle and part throttle in order to run at stoich.
I don't think logging 02 voltages at part throttle was a brilliant idea because of this, but just my 2 cents. IMO, your log is worthless and is of absolutely no importance. But then again, maybe I'm missing something!?
I only did the log because someone on here recommended that I log it at 1/2 throttle (because....
... I am having my boost surge issues at 1/2 throttle). Like I said, I don't know what I'm looking at with that graph anyway, only did it cause someone recommended that I should (I'd love to find the post, but the STFA and Beta STFA are both worthless, say I only had 1 post in the last 2 weeks *rolls-eyes*).
How would a CQ run if the throttle position sensor is not hooked up and shouldn't that trip the chec
|skolnick
10-10-2006 03:37 PM
jhoeppel
12-29-2005 10:24 AM
bagodoosh
04-15-2005 06:26 AM
