Humpday discussion topic: are Tracksports (eg 700/800) too harsh for street-only driving?
I know there's no "best" suspension, that it depends a lot on intended use and personal preference, but I am just interested to hear different peoples' opinions. So...
If you drove ONLY on the street (primarily in NJ) and if the price for Stasis Tracksports and Stasis Streetsports were the same, which would you choose? And why?
Also, as an additional question, if a person opts for the Tracksports, is an aftermarket rear swaybar recommended as it is for the Streetsports?
Thanks for the input.
Sincerely,
-Fairenough, a true suspension noob.
Sincerely,
WARNING: if you get Track Sports, I'll swap them with my Street Sports when you're sleeping!! (edit)
I would definitely ge the track sports with 600/700 spring rates and the sport valving. I'm not sure about the sway bar but the EF setup uses it and I already have it...<ul><li><a href="https://forums.audiworld.com/s4/msgs/1737676.phtml">Fletcher setup</a></li></ul>
rear sway bar, stasis sales people say...
a rear sway bar is not recommended for high-ish spring rates (700/800) unless you have a rear lsd to accomodate wheel lift in corners.
or at least thats what they told me a month ago when i asked the same question. then again, i'm sure they'd be more than happy to sell you a rear lsd.
