I'm not sure I can afford to run this old 93 code much longer!
Here's some background. I've used 100 octane for the past year or so. I filled with 93 recently due to being dead empty and not wanting to drive over to the sunoco. I immediately noticed the boost gauge showing 17-18 psi, tapering/flat-lining to 15 psi. The car has the acceleration of a rental ford festiva. I know for a fact that the 93 code ran 20+ psi this past summer.
OK, I thought back and remembered that I tweaked my new N75 awhile back, so I assume I screwed it up. The 100 software doesn't run much more than 16-18, so I didn't notice it before. I went ahead and spent $110 for a second new N75 while I was at the dealer getting other stuff.
The new N75 didn't change the boost from 15psi! I went out to the garage and did a very thorough boost leak test last night and spent over an hour trying to find the slightest leak. It was a waste of time.
Here's the graph that I just recorded:
<img src="http://dave-new.com/S4/1st_and_2nd1.gif">
Lesson: Log data before you do anything else.. I didn't have a boost gauge last winter so I didn't know the 93 code (apparently) runs lower boost when it's cold.
I'll be glad to get the new software
yea, I *might* try 100 octane with the updated 100 software:)
I forgot to tell you, the current 452hp dyno chart on APR's site says it's for 100 octane, not 104.
