Just Recieved my Fidanza LwFw w/ Rs4 Clutch, !
I have to do my RMS (leaking like a SOB!), So i figured a new clutch, flywheel, and make some piggies, this should help for some good HP GAIN! ANother step closer to stage 3....
Like I told you previously sir, your RMS is/was leaking
Remember I mentioned that? That is what the oil and gunk inside your transmission bell housing was.
RMS = Rear Main Seal. Behind the flywheel/crank. It leaks with time, it's just a gasket basically. It leaks oil, not transmission fluid. Bad enough, it'll get onto the clutch disk and cause it to slip. I still have pics of yours if you deleted them.
the seal drying up (coolant leak) and the white goop coming apart (oil leak)
<img src="http://pictureposter.audiworld.com/47312/dirtrearmain.jpg">
<img src="http://pictureposter.audiworld.com/47312/dirtrearmainview.jpg">
radron26
08-12-2007 08:42 AM
davematthews-S4
12-11-2002 08:24 AM
escargot
13
05-31-2002 09:14 PM
