Kiddies, I need your thoughts on Water Wetter.
I've read that it's much better for cooling your engine, but doesn't have any anti-freeze properties
so don't use it in a cold climate! In fact, plain water is supposed to be better at cooling the engine compared to standard coolant.
I can't wait to find out. Well the test was 5 pages long. :-( Wasn't to bad. Guess we will see when
I get it back. Now I have to wait till 12:50 for psychology. The mind fkcuing class. :-)
Water Wetter is a coolant additive, not a coolant.
You use it <i>with</i> your antifreeze. Helps reduce the surface tension of the coolant to help it flow into every nook and cranny in the block.
Water Wetter is said to work optimally in a coolant mixture that's mostly water, but that's not convenient for most people's daily drivers. It still does a good job with a water/antifreeze mixture.
gimmick. several companies have tested these agents.... plain water is always the best,
you may want additives for anti-corrosion or anti-freeze. but for cooling efficiency nothing is better than plain water.
-alex
-alex
