Lemmiwinks Gurus: csv inside. Looking for recommended adjustments
Car is currently -18% primary.
I am happy with the MAF flow 318 g/s. But I am not happy with the high CF's and O2 voltages. Also at WOT the timing is around 12, which suggests to add fuel, but the 02's seem to already to reading rich.
Block 32 reads .4 .8 .6 .8
Thanks for any help.
,Group A:,'003,,,,Group B:,'020,,,,Group C:,'031,,,
,,Engine speed,Mass air flow,Throttle angle,Ign timing,,Cyl 1,Cyl 2,Cyl 3,Cyl 4,,O2S volts pre TWC,O2S volts post TWC,b2 pre TWC,b2 post TWC
,TIME,,g/s,0-5deg=closed,deg,TIME,,,,,TIME,,,,
Marker,STAMP, /min, g/s,%, ?BTDC,STAMP, CF, CF, CF, CF,STAMP, V, V, V, V
1,26.39,4280,20.42,9.4,38.3,25.78,0,0,0,0,26.08,0. 08,0.04,0.07,0.035
,27.32,4240,31.67,12.9,36.8,26.7,0,0,0,0,27.01,0.7 1,0.095,0.705,0.11
,28.25,4200,30.86,12.5,37.5,27.63,0,0,0,0,27.94,0. 05,0.6,0.05,0.71
,29.17,4200,31.36,12.9,36.8,28.55,0,0,0,0,28.86,0. 58,0.555,0.34,0.635
,30.11,4520,292.39,100,1.5,29.48,9,8.3,9,9,29.79,0 .79,0.765,0.79,0.79
,31.09,5160,295.67,100,8.3,30.42,15,15,15,15,30.75 ,0.89,0.905,0.885,0.895
,32.15,5800,309.83,100,11.3,31.44,15,12,12,15,31.7 9,0.885,0.9,0.88,0.89
,33.26,6360,318.53,100,12.8,32.51,15,15,11.3,15,32 .88,0.89,0.895,0.88,0.895
,34.33,4880,9.72,5.9,7.5,33.65,10.5,10.5,10.5,10.5 ,34,0.74,0.83,0.755,0.845
,35.24,2960,8.86,4.3,3,34.65,0,0,0,0,34.94,0.02,0. 83,0.01,0.845
,36.15,1360,4.83,1.6,6,35.55,0,0,0,0,35.85,0.005,0 .015,0.005,0.005
,37.04,960,4.44,1.6,2.3,36.45,0,0,0,0,36.75,0.74,0 .005,0.67,0.005
,37.96,800,4.47,2,9,37.36,0,0,0,0,37.65,0.845,0.07 5,0.095,0.07
,38.87,2760,7.83,3.9,3.8,38.25,0,0,0,0,38.56,0.83, 0.18,0.05,0.125
,39.77,2680,7.58,4.3,4.5,39.17,0,0,0,0,39.47,0.02, 0.03,0.015,0.025
,40.68,2600,7.72,4.3,4.5,40.07,0,0,0,0,40.37,0,0.0 05,0,0
,41.58,2560,7.92,4.3,4.5,40.98,0,0,0,0,41.28,0,0,0 ,0
,42.48,2480,13.97,7.5,36.8,41.88,0,0,0,0,42.18,0.0 3,0.02,0.035,0.02
,43.39,2520,18.11,9.8,37.5,42.79,0,0,0,0,43.09,0.7 7,0.075,0.77,0.09
,44.3,2480,19.89,9,36.8,43.69,0,0,0,0,43.99,0.11,0 .105,0.09,0.15
,45.2,2480,11.08,6.7,39.8,44.6,0,0,0,0,44.9,0.05,0 .39,0.035,0.325
,46.11,2440,10.39,7.5,39.8,45.51,0,0,0,0,45.8,0.75 5,0.11,0.1,0.08
,47.01,2440,20.17,9.8,37.5,46.41,0,0,0,0,46.71,0.0 45,0.055,0.045,0.05
,47.92,2440,18.89,9,37.5,47.31,0,0,0,0,47.61,0.78, 0.13,0.78,0.14
,48.82,2400,15.61,8.2,38.3,48.23,0,0,0,0,48.52,0.6 45,0.34,0.655,0.485
,49.73,2400,15.61,8.2,38.3,49.12,0,0,0,0,49.42,0.0 4,0.54,0.035,0.59
,50.63,2360,16.61,7.5,39,50.03,0,0,0,0,50.33,0.15, 0.49,0.075,0.52
,51.54,2360,18.36,9,38.3,50.93,0,0,0,0,51.24,0.735 ,0.065,0.75,0.06
2,52.44,2360,17.94,9.8,36.8,51.84,0,0,0,0,52.14,0. 765,0.19,0.765,0.21
,53.35,1800,6.58,2.7,6.8,52.74,0,0,0,0,53.04,0.82, 0.475,0.81,0.535
,54.25,1040,5.19,1.6,23.3,53.65,0,0,0,0,53.95,0.03 5,0.59,0.015,0.625
,55.17,4080,70.14,25.9,14.3,54.55,0,0,0,0,54.86,0. 035,0.095,0.035,0.095
,56.09,4160,69.5,20,13.5,55.48,2.3,3,2.3,3,55.78,0 .735,0.67,0.675,0.7
,57.02,4240,53.72,14.5,6.8,56.4,2.3,3,2.3,3,56.71, 0.7,0.25,0.71,0.16
,57.91,2640,8.72,4.7,2.3,57.31,0,0,0,0,57.61,0.03, 0.04,0.03,0.02
,58.82,2320,53.69,27.5,18,58.21,0,0,0,0,58.52,0.28 5,0.03,0.09,0.025
,59.72,2360,39.86,16.1,30,59.12,0,0,0,0,59.42,0.13 5,0.36,0.17,0.67
,60.63,2400,48.28,17.3,30,60.03,0,0,0,0,60.33,0.67 5,0.61,0.195,0.59
,61.53,2440,42.31,16.5,30.8,60.93,0,0,0,0,61.23,0. 07,0.375,0.085,0.57
,62.44,2480,37.5,14.9,30,61.85,0,0,0,0,62.14,0.145 ,0.235,0.64,0.585
,63.34,2520,32.56,14.5,31.5,62.75,0,0,0,0,63.04,0. 735,0.085,0.75,0.11
,64.25,2520,32.67,12.9,33.8,63.65,0,0,0,0,63.95,0. 74,0.315,0.715,0.66
,65.16,2520,29.31,12.9,33.8,64.55,0,0,0,0,64.85,0. 59,0.665,0.56,0.71
,66.06,2520,42.83,16.5,30.8,65.46,0,0,0,0,65.76,0. 65,0.655,0.63,0.655
,66.96,2560,41.92,16.5,30.8,66.36,0,0,0,0,66.67,0. 185,0.58,0.205,0.615
,67.87,2560,34.33,14.1,32.3,67.27,0,0,0,0,67.57,0. 445,0.215,0.205,0.09
,68.77,2560,25.06,11,36,68.17,0,0,0,0,68.48,0.71,0 .61,0.71,0.615
,69.68,2560,23.69,10.6,36.8,69.08,0,0,0,0,69.38,0. 115,0.545,0.16,0.565
,70.59,2560,23.72,10.6,36.8,69.98,0,0,0,0,70.28,0. 7,0.595,0.575,0.59
,71.49,2560,29.72,12.9,35.3,70.89,0,0,0,0,71.19,0. 085,0.565,0.11,0.55
,72.4,2560,30.81,13.3,33.8,71.79,0,0,0,0,72.09,0.7 65,0.64,0.765,0.63
,73.3,2560,34.94,14.1,32.3,72.7,0,0,0,0,73,0.65,0. 64,0.695,0.7
,74.21,1560,5.33,2,6,73.6,0,0,0,0,73.9,0.505,0.66, 0.07,0.75
,75.11,1000,4.06,1.2,3,74.5,0,0,0,0,74.81,0.045,0. 645,0.035,0.735
,76.02,1840,6.33,2.7,34.5,75.41,0,0,0,0,75.71,0.84 5,0.08,0.845,0.05
,76.94,4320,63.56,22,18,76.32,0,0,0,0,76.63,0.06,0 .06,0.055,0.045
,77.89,4400,53.72,18,33,77.26,0,0,0,0,77.57,0.745, 0.75,0.635,0.72
,78.84,4440,42.08,15.7,34.5,78.2,0,0,0,0,78.52,0.6 4,0.65,0.725,0.59
,79.78,4440,37.78,14.1,34.5,79.15,0,0,0,0,79.47,0. 225,0.625,0.135,0.62
,80.73,4440,57.61,18.8,13.5,80.1,0,0,0,0,80.41,0.7 5,0.66,0.755,0.725
,81.68,4520,58.19,18.4,33,81.05,0,0,0,0,81.36,0.66 ,0.37,0.585,0.38
,82.64,4560,53.22,18,33.8,82,0,0,0,0,82.31,0.505,0 .38,0.475,0.28
,83.58,4280,11.97,5.9,6,82.95,0,0,0,0,83.28,0.725, 0.355,0.725,0.55
,84.5,3560,52.03,18.8,18.8,83.88,0,0,0,0,84.19,0.0 35,0.615,0.035,0.095
,85.39,3600,47.47,16.9,33.8,84.8,0,0,0,0,85.1,0.55 ,0.68,0.69,0.79
,86.31,3600,43.69,16.9,34.5,85.71,0,0,0,0,86.01,0. 67,0.635,0.645,0.69
,87.21,3640,46.64,16.9,26.3,86.6,0,0,0,0,86.9,0.69 ,0.185,0.715,0.165
,88.12,3680,47.92,16.9,34.5,87.52,0,0,0,0,87.82,0. 085,0.2,0.18,0.33
,89.02,3720,49.03,16.9,33.8,88.42,0,0,0,0,88.71,0. 085,0.445,0.07,0.535
,89.93,3720,43.53,15.3,34.5,89.33,0,0,0,0,89.63,0. 69,0.13,0.7,0.095
,90.83,2920,9.75,5.1,3,90.23,0,0,0,0,90.52,0.035,0 .56,0.025,0.165
,91.73,2200,6.03,3.1,8.3,91.13,0,0,0,0,91.43,0.73, 0.035,0.595,0.03
,92.66,4400,17.58,9,33.8,92.03,0,0,0,0,92.34,0.025 ,0.035,0.02,0.03
,93.61,4440,31.31,12.5,36,92.98,0,0,0,0,93.29,0.66 ,0.095,0.1,0.06
,94.55,4400,33.67,13.7,16.5,93.92,0,0,0,0,94.24,0. 065,0.655,0.06,0.635
,95.49,4360,14.22,8.6,37.5,94.87,0,0,0,0,95.17,0.7 1,0.385,0.71,0.325
,96.43,4400,146.33,89,33.8,95.8,0,0,0,0,96.11,0.74 ,0.055,0.765,0.065
,97.4,4960,284.36,100,7.5,96.74,12,15,15,15,97.07, 0.87,0.885,0.86,0.88
,98.44,5600,301.11,100,12.8,97.74,12,15,12,15,98.0 8,0.89,0.9,0.88,0.89
,99.53,6200,318.53,100,12,98.79,12,15,11.3,15,99.1 6,0.885,0.895,0.875,0.89
,100.62,5240,6.03,5.5,8.3,99.9,15,14.3,11.3,14.3,1 00.28,0.63,0.7,0.655,0.84
,101.55,3320,12,4.7,1.5,100.94,0,0,0,0,101.25,0.84 ,0.845,0.83,0.855
,102.45,1800,6.39,2,6.8,101.85,0,0,0,0,102.15,0.00 5,0.495,0.005,0.01
,103.36,3360,9.83,4.7,2.3,102.76,0,0,0,0,103.06,0. 005,0.005,0.005,0.005
,104.27,3280,9.33,4.7,0.8,103.66,0,0,0,0,103.96,0, 0,0,0
,105.17,3240,9.81,4.7,0.8,104.57,0,0,0,0,104.87,0, 0,0,0
eigenvector
15
11-04-2006 08:05 PM
sskappel
07-11-2005 12:30 PM
back2black
07-21-2004 11:55 PM
