Lemmiwinks - Secondary fuel tweak
Does anyone have any solid data as to what the secondary fuel tweak does ? The lemmiwinks guide is vague, I've been told that it's used to adjust fuel under accelleration.
I would guess there are some advantages to utilitzing secondary fuel tweaks as apposed to just using the Primary fuel tweak. Allowing you to adjust the primary fuel tweak closer to 0, whih in return would allow you to idle leaner as well as cruise a leaner.
The secondary fuel tweak would allow you to richen the mixture under accelleration when it's needed most.
Running OK .. I think I have an oil leak somewhere, I can smell it burning when I
turn on the climate control Going on vaction the first week of October. May want to leave it with you to see if you can find/fix it.
JDMnAR
02-22-2008 10:53 AM
beejohn
05-29-2006 10:20 AM
HOPSBurner
Chicago Discussion
07-15-2005 01:53 PM
