Limp mode at the track this weekend - EGT sensor causing it?
Old Apr 13, 2009 | 09:33 AM
nadrealista's Avatar
Default Limp mode at the track this weekend - EGT sensor causing it?
ran with stock chip to keep k03 from exploding...
after 3 session check engine light came on..I scan the car and see code for one of the EGT sensors and one secondary O2..clear the codes and continue. all running good.
Second day I am on my way to the track it was cold..low 30s..I needed to pass someone and I get on it..limp mode only 5psi of boost..first session on the track boost was normal again(for stock chip) just hair below 10psi?
before second track session I put in MTM ecu , car goes into limp mode toward the end of the session..no CEL..after cool dawn car got out of limp mode and boosted fine!?
swap back to stock ecu for 3rd session, limp mode again in the middle of the session now..still no CEL light..
could this be caused by bad/going EGT sensor?
These suckers are expensive, how about just deleting them..where was that delete writeup?
Where is best place to buy them if delete is not an option?
Old May 1, 2009 | 08:09 PM
Default BUMP!
Would limp mode be recorded in as a code in ECU?
Old May 2, 2009 | 05:11 AM
Afterthought's Avatar
Default Limp Mode
I'm not sure of all the different scenarios that can cause limp mode. My car has been overboosting and going into limp mode. When this happens, all I see for codes is 'charge pressure- upper limit reached"
So far I have pressure tested, and taken apart and lubed my diverter valves but I still dont know what is causing this.
Old May 4, 2009 | 10:21 AM
RolledMySTi's Avatar
Yes a bad egt will send you into limp mode. Limp mode will not show up as a fault in the ecu.
Old May 4, 2009 | 01:21 PM
complacentsee's Avatar
Vast has a delete tune.
I posted a site that has them indv. for 240ish each.
Old May 4, 2009 | 01:22 PM
Your issue is not related. Overboost limp is caused by the valve that operates the wastegates OR(!!!!!) your specific tune causes it and you should use a manual boost controller to solve this.
Old May 4, 2009 | 05:06 PM
slowEURO's Avatar
Specifically what valve would this be? Remedy?
Old May 4, 2009 | 05:12 PM
akwardly enough the post describing this was bumped today by a spam bot. N75 is the modulation valve, but don't play with it unless you know what your doing.
https://www.audiworld.com/forums/sho...php?p=12748799
Old May 4, 2009 | 06:08 PM
slowEURO's Avatar
Ok gotcha, I'm familiar. I just was overthinking haha. Thanks man.
kelbrig1
Oct 30, 2007 07:17 PM
Nogaro Nitwit
Nov 20, 2006 12:36 PM
SebGood
Oct 10, 2005 07:34 AM
2000s4biturbo::Uli
14
Jan 27, 2004 10:32 AM
