Looking for DIY on spark plugs. anyone? TIA
Thanks, I forgot to be specific. I have never done it on the S4 (change the spark plug, I mean)
so is it a consuming amount of time and does it require to remove many other component to gett to them besides the already mentioned? Thanks
You don't have to unbolt Y pipe
Other than that, Underpressure's post has it pretty well covered. I did mine this past weekend. The front passenger side (#1?) coil pack's front mounting screw is under the Y pipe, but you can easily reach it from the front with a 10 mm wrench. Be sure the check the gaps on your new plugs - the Denso's I got were all over 0.65 mm out of the box.
If only changing the fuel filter and bleeding the clutch were as straightforward!
audiquattroduo
04-11-2008 12:02 PM
