My dealer did pressure test on my coolant and said everything is fine.. but coolant still decreases
I havent seen any visible leak at all.. I took my car to dealer 3times.. never find any visible leak
with dye the coolant...
they did pressure test... nothing wrong
but the coolant level decrease pretty fast
not really fast but have to fill once a week
could be a small leak somewhere.......(more)
i've seen afterrun coolant pumps with small leaks but they will still pass the test when the coolant system is pressurized.
If possible i'd pull the engine covers off and look around for any dried pink coolant around any of the coolant line connections. Common places could be in the valley between the heads as well as the hard line that runs between the two heads on the back of the motor.
don't know what to tell you.....tough to diagnose if no visible leaks and pressure test checked out
Your engine pull isn't too far away so hopefully you can get to the bottom of it then.
