Need Radar Detector help
Guest
Posts: n/a
Given that my S4 will be here in about 4 weeks, what is the best radar detector that I can get. I would really like something that can be installed in the dash so that it is out of the way. Any help would be much appreciated. Thanks
Guest
Posts: n/a
Valentine One is the BEST
However, they are wicked expensive.....fortunately mine was a gift. There is an option to install them directly into the car's electric system with concealed display modules to hide their presence in the vehicle. Go here for more info:
http://www.valentine1.com/
Guest
Posts: n/a
Two Choices...
In-Dash = K40 and cost is $1000+
On Window = Valentine 1 and cost is $399
My father in-law bought the K40 for his M-Roadster. He was going to puchase the Valentine 1 (V1) but I said "If your going this far you might as well...". He also wanted the laser diffuser, which the K40 offers.
I bought the Valentine 1 and it is the best I have owned to date. I have had Cobra, Passport and Bel.
If cash is an issue then go with the Valentine. It is well worth the $399 and saved me 3 times on Memorial Day weekend. The range is incredible, and does not go off for just anything...
-PeteW
-PeteW
Guest
Posts: n/a
Re: Two Choices...
Thanks for the info. Does the K-40 have more range than the Valentine? Is it much better or is it just more expensive because it is dash installed? What is the laser diffuser? Any other differences between them? Also, is there a web site where I can get info on the K-40. Your help is much appreciated
Guest
Posts: n/a
Re: Need Radar Detector help
Two best detectors available are K40 and Valentine One. I just purchased a V1 one month ago, and have been extremely satisfied. It is the only detector that will tell you radar DIRECTION. K40 is custom installed in your vehicle and is a muti-sensor, multi-piece unit. It's performance is no better than the V1. V1 is, ideally, a windshield mounted unit (it uses a front and rear antenna, but for $39 or 49, you can get a concealed display unit that routes all the readouts to a small unit you can mount anywhere. Also, V1 is portable, K40 is not. The K40 laser diffuser is a unit that is desguised as a front license plate holder that essntially jams laser guns by emitting some kind of light at some kind of wavelength. Cost: V1=$400 K40=$1000 Diffuser=$340. In my opinion, V1 + Diffuser would be the best combo.
Guest
Posts: n/a
Thanks for the info. I would like to find out more about the $39 display option that you mentioned. You say it routes the display info to a small hidden screen. So you would still have to have the full unit mounted on the windshield. Am I correct? Or can the main unit be hidden as well. Thanks
