OK so I've STFA all day long and can't find a writeup on an S4 clutch install, just A4 writeup?
Is there a writeup online somewhere that has the S4 tranny pulling? I've check S4Biturbo.com, S-cars.org and the archive here with no luck? Is it a lot different than the A4 swap other than the obvious tranny difference? Thanks guys.
Shouldn't be all that different...
<center><img src="http://pictureposter.audiworld.com/38083/cimg2032.jpg"></center><p>Though I've never pulled just the tranny. In a home-garage it's easier to do a whole engine-pull.
Mike, what do you think of this setup?
Bosch Green Giants (Volvo)
3.7Bar FPR
Zeitronix AFR Meter
90mm MAF
RS6/K04s
Revolver Cams
GIAC X Tweaked
ASP "Wide Mouth" Intake Manifold
Oil Catch Can
Apexi AVCR
Piggie DPs w/ Dumps
Open Element Intake
Vertical mount 1300CFM FMIC
Suggestions? I am just pondering late at night for fun.
3.7Bar FPR
Zeitronix AFR Meter
90mm MAF
RS6/K04s
Revolver Cams
GIAC X Tweaked
Oil Catch Can
Apexi AVCR
Piggie DPs w/ Dumps
Open Element Intake
Only if you have a long garage
It's a bit of a squeeze in a standard garage
<img src="http://pictureposter.audiworld.com/58573/img_3102_medium.jpg">
Suspend the engine, drop the sub-frame and remove the tranny is way easier
<img src="http://pictureposter.audiworld.com/58573/img_2679a.jpg">
That looks pretty well orchistrated ;)
The only thing I'd be worried about is how much a PITFA putting the tranny back on is. With the engine on the floor it can sometimes be a real pain.
The Bentley manual is pretty good, but don't believe the part about the SAC mechanism
being set from the factory - make sure you know how it works and how to tell if it's set properly.
Mike's comment below is very interesting, I never considered pulling the entire engine/tranny assembly - I guess pulling just the tranny in my garage on jackstands means I'm qualified to swap turbos now!
Email me if you have more questions.
