Oxygen Sensor Modification
#11
The sizing of this diode is really more indepth than picking up your local radioshack rectifer diode. Since you wired it correctly and are having this issue. I would say try a small signal diode in place of the rectifier diode.
#13
#17
Before the mod I had up to 1.2volts.
After the mod I got max .45volts.
However, after the mod I got these codes:
17522 - P1114 - Bank1-Sensor2 Internal Resistance too High
17548 - P1140 - Bank2-Sensor2 Internal Resistance too High
What's strange is the mod did what it's supposed to do by
achieving .45volts.
However I got a CEL with the following codes above.
#18
If the voltage hits zero with the mod (as in the minimum voltage), it will have "infinite" resistance. The diode will be turned off and there is no more connection to the O2 sensor.
#19
