PIGGIE SS... NEED INFO..
How many of you guys have piggies?
1. Are you using it stock height with shorter throw?
2. Have any of you had the vast piggie shortented to have even lesser throw?
3. How are either setup doing for you guys?
Thanks for all your comments...
i have the "SPBTGBNOTSDS shifters"........
ie. ToyGuy
1)yes, stock height
2)Craig (ToyGuy) was supposed to shorten 1"...but he "Forgot" and shipped it stock height
3) Excellent...buttery smooth, recommended =)
1)yes, stock height
I reduced the height 1" I like it. I shortened it 1" since I had the B&M SS and
had to modify the boot (remove 1" of the plastic tube at the top of the boot) to make the B&M work. I probably would have only shortened it another .5" but probably can't tell the difference.
One advantage of having 1" removed, I was able to install the shifter assembled. I slid the shifter down the linkage shaft, and then lifted the threaded part up through the center.
B56
08-14-2008 10:43 AM
BlackAvantA4Guy
12-16-2005 12:06 PM
XTHCX
04-15-2004 10:27 AM
S4's for all
24
09-24-2003 11:14 AM
