Question about oil leakage coming from the return line on my turbos....
Had my car in for a routine service and when I went to pick the car up I was informed that the oil return line coming off the turbo going back to the oil pan is leaking a small ammount of oil. (not allot but there is some sepage)
I was then told this is common and nothing to worry about. My question is this something I should be concerened with and is this "normal and or common?
Also on a side note I am running KO4s
Are you sure it's not oil coming from above.....I was just looking for an oil....
leak on my dad's A6 2.7T - I initially saw some oil on the oil return line - realized pretty quick it's coming from above - probably valve cover gaskets, cam seals or cam adjuster gaskets.
Maybe it's dripping down from above - just a thought.
FIrst & foremost, I'd say clean it completely, drive it, and make sure it's
actually leaking. It may also be just a loose bolt on the return line, or the oil feed line may need to be tightened a little more. IMO, it's more common to see the feed line leaking after a turbo swap.
Dr. Back Crackin S4
02-22-2008 07:12 AM
nadrealista
12-20-2005 11:27 AM
AbnormallyAspirated
01-29-2002 04:26 AM
