Rough idle, Help!
Rough idle, Help!
as of today I have replaced the spark plugs with NGKs, ran seafoam in the gas(8 gallons of gas),cleaned MAF sensor, replaced S2B2 O2 sensor and still have the problem and I am not getting any CELs. My gas mileage is about 27mpg and runs smooth down the highway. I STF and found something about temp sensor or EGT sensors that may cause problems and not give any CELs. HELP!!!
With 67k on it now I think it`s time for a new belt...
I let it set for 5 mins after upgrading my ECU. Had the same problem before changing to the APR chip.
Yeah it is getting to be about that time. Mine was pretty rough before I changed my timing belt.
The RPMs didn't jump around much and I wasn't throwing any codes so I didn't worry about it. Since I did the Timing Belt/Water Pump in December it has been smooth as butter. Note that I did my spark plugs in Dec too, so the T-Belt wasn't the sole factor to eliminating my rough idle.
