Tie rod end help Por favor
How many of you used a jack to jack up the suspension when doing TREs.
I see why this might make it easier to do the TRE but it seems dangerous with a loaded suspension.
With stiffer suspension wouldnt you also run the risk of pushing the car off the jack stands.
So guess my question is; is it necessary to jack the suspension and how much harder am i making it on myself if i don't
TIA
TIA
well...
the tires have to come off so I did it with the load off. Jack stands under the jack mounts and a jack under the suspesnion. you have to really jack way beyond common sense (the suspension that is) for it to be dangerous. It will come apart without taking the load off though.
Agreed. just put ECS on my car
<center><img src="http://www.ecstuning.com/stage/images/product/iadmin/2197_x600.jpg"></center><p>You can really see the difference with the ECS - much, much beefier...
27S4
01-08-2006 03:17 PM
