Tool list for DYI Timing belt?
I'm about to do all this......
AWE intercoolers
RS4 oil cooler
crank pulley
seal up the heads, I have all the gaskets
full TB kit
So the question is what tools are NEEDED & what ones are nice?
I'm going to buy the cam bar, not sure what else. Are the cam seal tools really needed?
AWE intercoolers
RS4 oil cooler
crank pulley
full TB kit
You *need*
cam lock bar and crank lock pin
That's about it, I've done 8 of them and never used the chopsticks tool. A crescent wrench gets that bolt. Just remember, it's reverse thread.
Obviously, you'll need the regular tools, good set of metric/allen sockets, torx bits etc. Torque wrench too.
1. I can rent you my cam lock bar. 2. Are you going to pull the entire front, or just ...
move it forward into service position.
The tranny cooling lines on a tip are a serious PITA. I was given advice after the fact that would have been helpful.
If you are just going to move the front the clip into service position, then it is a moot point.
We did my tip, then we did a 6spd a few days later. The only major difference was the tranny cooler.
Other than that, the standard procedure applies.
In hind sight, I would have applied a bit of sealant to the water pump gasket but no one seems to recoomend that. Remember that the fan is reverse threaded! The cam pulleys are a bit scary to pop off, we used a gear puller.
Otherwise, have fun.
divil
11-05-2011 08:13 AM
1999Audi
04-15-2007 04:15 PM
ocrazy
Audi 100 / A6 (C4 Platform)
03-08-2006 11:57 AM
shwndh
12-23-2003 04:22 PM
