Turbo timers vs keyless entry... Ways to bypass?
Old 05-23-2007, 02:32 PM
Pscheoverdrive's Avatar
Default Turbo timers vs keyless entry... Ways to bypass?
Since the car is still running when you take the key out, the keyless lock is disabled. Is there a way to mod the system so as to allow keyless control while the car is still on?
I searched already... Wasn't sure what to look for specifically.
TIA!
Old 05-23-2007, 02:38 PM
lovethepow's Avatar
I dont know about stock, but my clifford overrides it.
Old 05-23-2007, 02:44 PM
OSin456's Avatar
Default I did it this way. Easiest I think.
Check out my post #12.
instructions I had seen had suggested tapping into one of the wires behind the fuse box. I couldn't find and, and after some thinking I figured out that doing what I did accomplished the same thing, and eliminated the chance of tapping the wrong wire, or cutting it completely. Works flawlessly.<ul><li><a href="http://audizine.com/forum/showthread.php?t=57807">http://audizine.com/forum/showthread.php?t=57807</a</li></ul>
Old 05-23-2007, 02:51 PM
Default Interesting... I have a GReddy TT; is yours an Apex?
I'm not sure which wire is the 'security wire'... What function does it serve on yours?
The GReddy has five wires:
-Main power
-Switched power
-Ignition
-Speedometer in
-Emergency brake
...E-brake cuts the timer if the signal to the wire is cut.
Old 05-23-2007, 02:52 PM
daves4izzle::ASP 3-'s Avatar
Default My car operates with the car running off the TT exactly the same as it does when it's off.
Stock security system and standard TT wiring scheme.
Old 05-23-2007, 03:00 PM
Meaning you went through the steering column's wiring? I used the writeup in the tech section.
Old 05-23-2007, 03:04 PM
OSin456's Avatar
Blitz DTT, I forget what wire it was on the TT. Whatever one is supposed to tap Fuse 6.
Old 05-23-2007, 03:20 PM
Member
Island Boy::Jeproks's Avatar
Where in Laurel are you? I have the Greddy TT and operates fine w/ the keyless
Old 05-23-2007, 03:24 PM
By standard scheme I meant standard b5 chassis wiring scheme as per the tech articles.
Old 05-23-2007, 03:43 PM
Junior Member
b5s402's Avatar
Default its easy, i used a writeup that told me how to re-wire the locking and alarm system to the constant
on source instead the momentary, so that i can activate the alarm ,and lock/unlock while the car is still running..
umm search in the tech articles for turbo timer install..
Quick Reply: Turbo timers vs keyless entry... Ways to bypass?
