whats the best way to take the front o2 sensor apart?
<center><img src="http://pictureposter.audiworld.com/26857/o2sensor.jpg"></center><p>i want to remove the contacts, so i can wire up the vw o2 sensors.
Someone posted on this a few days ago.
Easiest is to cut off the VW connectors and buy new ones from Audi. Or, you can do like I did and use a flatened piece of solid wire and slide it between the ear on the pin and the connector to release it. But it's a PITA.
Re: i am trying, but not to sure where to put the wire.
i just did a search and found the post from a few days back. i've got the part number, going to order it from the dealer on wed.
thanks
thanks
Honestly, that's probably the best. I didn't know you could get just the connectors
when I did mine, or that's the route I would have taken. It wasn't easy releasing the pin tabs. Another alternative..I undertand that the dealers have a kit that includes the tool to release the pins. Maybe you could bring them to the dealer and they would swap then for a minimal fee, but I bet the new connectors would be the cheaper way to go. I tried buying just the tool but they said it wasn't sold sans kit.
Re: is this the part? Wire Terminal Extractors
<center><img src="http://www.gprparts.com/brands/sirtools/images/9701or9702.JPG"></center><p><ul><li><a href="http://www.gprparts.com/brands/sirtools/audi.asp">http://www.gprparts.com/brands/sirtools/audi.asp</a</li></ul>
brad131a4
12v V6 Discussion
18
11-28-2005 12:36 PM
tdotquattro
12
06-15-2005 11:04 AM
AEGA4
05-19-2003 10:48 AM
Jeremy Clarkson
09-25-2002 07:04 AM
