S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
Launch control will it destroy the transmission
Old 11-11-2013, 11:12 AM
  #11
NeddyPlast's Avatar
Just got a reply from the tech, he said its the mechatronics unit and yes its VIN specific. He's at a NY dealer he said you can bring the car if need be.
Old 11-11-2013, 11:32 AM
  #12
NeddyPlast's Avatar
Originally Posted by ecpChris
Wonder if the launch counter is stored in the TCM. I doubt it but I just don't know how replacing that would fix the problem.
Hopefully it is not locked to VIN because in addition to buying one, you would have to get all that to jive
If i had to guess, its stored in the TCU, it just clicks up a number everytime it registers a launch. The value is actually counted in the ECM somewhere, i know that can be reset but it doesnt actually reset the counter in the TCU.
I think there was a thread somewhere in the B8 S4 forum on this. Replacing the mechatronics unit means you get the 0 count and can start launching again. Tech said Audi didnt warrant the part on the car he worked on.
Old 11-11-2013, 12:29 PM
  #13
Delurker's Avatar
I guess that begs the question as to whether they're going to TD1 you if you show up to the dealer with a lower counter than you had last time.
Old 11-11-2013, 12:52 PM
  #14
ecpChris's Avatar
I think his internal "counter" will be the same in the ecu. I bet since he hit the 200 mark, there is no doubt he will be TD1 and on the hook for any transmission work that may arise after the fact.
Old 11-11-2013, 04:39 PM
  #15
sciblades's Avatar
let me know if he needs any more info to shoot me out a quote
Address 02: Auto Trans
Control Module Part Number: 4G1 927 156 S
Component and/or Version: 0B5 40TFSINAR H01 0005
Software Coding: 000001
Work Shop Code: WSC 02391
VCID: 3D71849BACE36EF6BF5-8068
Advanced Identification/FAZIT
Identification: TFK-030
Revision: --H01---
Date: 29.06.12
Manufacturer number: 0902
Test stand number: 0608
Flash Status
Programming Attempts(application): 1/1
Successful Attempts(application): 1/1
Programming Status: 00000000
Flash Date: 12.08.09
Flash Date: 0000.00.00
Flash Tool Code: 00000 000 00000
Software
UDS: 02.00.03
ISO15765: 02.00.01
CAN: 02.14.02
HiSpd Net: 01.06.00
Misc.
Hardware number: 0B5 927 156 J
Workshop System Name: J217
ASAM Dataset: EV_TCMDL501021
ASAM Dataset Revision: 001010
Car Info
Chassis Number: WAUJ2AFC2DN042004
VCDS Info:
Labels: 0B5-927-156.clb
ROD: EV_TCMDL501021.rod
Old 11-12-2013, 08:27 PM
  #16
hermanz3's Avatar
200.
launchlimit.com
S6(C7) is not on the list of the website...
Old 11-12-2013, 11:08 PM
  #17
DeerHunter's Avatar
Maybe not, but sciblades has an S6 and can vouch for the fact that it's limited to 200 launches (post #4).
Old 11-23-2013, 10:32 AM
  #18
mikec7s6's Avatar
that's amazing some have hit the limit already. I haven't used it once in 10k miles yet, I don't know what my counter reads but if there is any on there, it was prob done by someone while getting serviced or valeted.
Old 12-06-2013, 09:44 AM
  #19
sciblades's Avatar
an update to all of this I am replacing my mechatronics unit, it will cost 3k all said and done but as I find the launch control to be the most important feature on my car it comes down to a "pay to play" situation.
Old 12-06-2013, 10:24 AM
  #20
snagitseven's Avatar
Just curious. Will the new mechatronics unit provide unlimited launches or is it limited to another 200 uses? If the latter, math with the $3K cost of a new unit works out to $15 per launch.
Quick Reply: Launch control will it destroy the transmission
