2014 A4 Bluetooth Music Streaming?
Old 08-22-2013, 04:15 AM
heisatouchdown's Avatar
Default 2014 A4 Bluetooth Music Streaming?
Hi all,
I just bought a 2014 A4 yesterday and I was trying to figure out if there was a way to stream your music via bluetooth, or if the only way is to plug in an ipod / SD card? Also, are there specific types of SD cards that you need to use or are any good?
Thanks in advance!
Old 08-22-2013, 04:24 AM
snagitseven's Avatar
Originally Posted by heisatouchdown
Hi all,
Thanks in advance!
If you have your car, reading the manuals is a must. If not yet...
If you have MMI 3G Nav Plus, this should help answer your questions:
https://www.audiworld.com/forums/sho....php?t=2840907
It's C7 oriented but the 2014 A4 Nav Plus system is very similar.
Old 08-22-2013, 07:28 AM
NJRoadFan's Avatar
If you have the MMI navigation option, your car supports A2DP Bluetooth streaming. Any paired phone will appear under the device listing when you press the Media key.
Old 08-22-2013, 09:39 AM
Unfortunately I do not have the navigation package, I only have the premium plus.
I'm guessing the only thing I can do is put in an SD card / buy an iPod?
Old 08-22-2013, 09:54 AM
Either will work (assuming you have an AMI cable for an iPod/iPhone) although the SD card will sound better.
Old 08-22-2013, 10:03 AM
Thanks for the help snagitseven!
Old 07-24-2017, 10:29 PM
ellain20's Avatar
Default stream music
Have you tried viseeO tune2air. I have mine and it works perfect. It streams music via bluetooth..plug it straight into the AMI or on your car's media port, job done.
Old 08-18-2017, 12:10 AM
Grace1991's Avatar
I am using tune2air from Viseeo USA, I just plugged in this bluetooth adapter then play my favorite music. I'm enjoying it!
snagitseven
A6 (C7 Platform) Discussion
455
09-10-2021 02:23 AM
Redd
Q5/SQ5 MKI (8R) Discussion
34
03-24-2016 10:07 AM
changareth
9
09-13-2015 10:58 AM
nextbond
11
09-22-2013 06:50 PM
boondagle
S4 (B8 Platform) Discussion
07-09-2013 03:49 AM
Quick Reply: 2014 A4 Bluetooth Music Streaming?
