Engine vibration at idle
Hi guys,
I have an Audi A6 3.2 08 and the engine vibrate a lot on idle on Park/D/N. When I touch the gas pedal it stops shaking. I dont have any check engine light or vagcom engine error. I dont suspect the engine mount 'cause the engine it self vibrate a lot when I touch it under the hood.
I suspect one of those things :
- carbon built up
- replace spark plug
- replace fuel injector
- replace head gasket.
Again I dont have any error on dash or vag.
Thanks for your help.
Julien
- carbon built up
Julien
Nope, but I had a lot of problems with this engine.
I did
- carbon cleanup
- head gasket
- fuel injector
- all spark plugs
- all coil pack
- water pump
- motor mounts
- all air filters
- v pan and oil cooler
- oil filter housing
- pressure test
- fix all vag error
The timing chain plate was leaking as well and I gave up.
After 2 years I sold the car on trade in at dealership.
I did
- carbon cleanup
- head gasket
- fuel injector
- all spark plugs
- all coil pack
- water pump
- motor mounts
- all air filters
- pressure test
- fix all vag error
'Bahn Burner
03-20-2002 03:01 PM
