Activate VZE traffic sign recognition
Old 11-17-2017, 12:00 PM
Debanks's Avatar
Default Activate VZE traffic sign recognition
Evening all, has anyone tried VZE activation with the following instructions- with or without parameterization?
Instructions here in German - https://audiwiki.bitt-c.at/index.php/VZE_aktivieren
In the following the necessary codes to activate the traffic sign recognition, if a front camera as well as the MMI navigation (goes with MMI navigation and with MMI navigation plus MMI touch) is installed. As a first step, the camera must be parameterized, otherwise it can not be coded.
Coding requires VCP for the parameterization of the camera!
Stand 14.03.2017: The parameterization / Flash file of the camera is sometimes only available for index A (8W0907217A)
Stand 25.04.2017: The parameterization / Flash file of the camera is now also available for index B (8W0907217B)
Stand 26.06.2017: The parameterization / Flash file of the camera is now also available for index C (8W0907217C)
STG 5F (Informationselektrik) [ edit ]
STG adaptation
Vehicle function list
Select BAP-traffic_sign_recognition_0x21 -> adjust value to active
Select Vehicle menu Operation-menu_display_road_sign_identification -> Adjust value to enabled
Select Vehicle Menu Operation-menu_display_road_sign_identification_over_thresho ld_high -> adjust value to enabled
STG A5 (front / apron camera) [ edit ]
STG access authorization
Enter release code 20103
STG Long Coding
Byte 1 -> enable bit 0
Note: With newer cameras, this applies instead: Byte 16 -> Bit 4 (with the current VCDS the bit is labeled)
STG adaptation
Select channel Display end of speed limit -> Set value to active (does not apply depending on the camera type)
Select channel Show valid additional characters -> Adjust value accordingly(does not apply depending on camera type)
STG 17 (dash panel insert) [ edit ]
STG Long Coding
Byte 5 -> enable bit 2
tomitza (01-08-2023)
Old 11-26-2017, 03:33 PM
brodoc77's Avatar
What does “paremeterization” of the camera mean?
Old 04-17-2019, 09:24 PM
gtwagon941's Avatar
Bumping an old thread, but wondering if anyone has further info on this? Has anyone been able to take a log from a car with this activated to understand how to do this with VCDS?
Old 12-23-2020, 03:36 PM
Hangtenboy's Avatar
I just purchased VCP which is required to parameterize the front lane assist camera. I will be updating the thread with the results, once I get it working and also the specific steps I took as those listed in this thread didn't work for me on my 2018 A4 B9
Old 12-24-2020, 12:04 AM
Void20's Avatar
Does anybody know if it's posible to parameterize with ODIS (ODIS - E)? And how?
Old 12-25-2020, 11:23 AM
Tesla1856's Avatar
I would really like this on my (similar) A5. I was thinking that since my car can already "super cruise" all the required hardware is here. Kinda strange they reserve it for the Prestige models.
I would not mind paying a bit for it since I don't have the tools or expertise with VCDS or OBDeleven .
I was hoping they would just add it to the new "Feature on Demand" in MIB3. Once I see the price, I can make a decision.
Old 03-06-2021, 05:14 PM
skynet01's Avatar
Does anyone know what to code for 2021 A5? I tried the following.. and looks like it's not working ...
Module 17
  • Byte 14 > Bit 6 = Active
  • Byte 5 > Bit 2 = Active
Module 5F
  • BAP-traffic_sign_recognition_0x21 = Active
  • Vehicle Menu Operation-menu_display_road_sign_identification = Active
  • Vehicle Menu Operation-menu_display_road_sign_identification_over_thresho ld_high = Active
Module A5
  • Byte 16 > Bit 4 = Active
All my cameras are already parameterized since I have ACC and 360 view
Old 03-08-2021, 06:21 AM
bruce_miranda's Avatar
Traffic sign parameterization is not the same as ACC and 360 view.
Old 03-08-2021, 10:00 AM
Tesla1856's Avatar
Originally Posted by skynet01
1. Does anyone know what to code for 2021 A5?
2. All my cameras are already parameterized since I have ACC and 360 view
1. I doubt it would be the similar. I would expect MIB-3 vehicles to be different than MIB-2/2.5 when it comes to coding/hacking.
2. I only vaguely know what that means, but I agree that our A5's already have all the hardware they need to do Traffic Sign Recognition. We just need some software.
Not sure if you have seen the new myAudi App v4, but there are hints that "Function on Demand" is finally coming online.
zemicars (04-28-2024)
Old 03-08-2021, 12:26 PM
skynet01's Avatar
Right, I was under impression that if you have ACC (Active Crusie Control) and 360 camera view option in your car the cameras are already parametrized and you don't need to worry about that step.
Quick Reply: Activate VZE traffic sign recognition
