Unable to reach correct operating temp
Old 04-24-2018, 12:11 PM
arne rosdal's Avatar
Default Unable to reach correct operating temp
After last service at the Moeller dealer, the car did not rech correct operating temp , temp was varying between 50 and 70 degree C. Down hill the temp was bearly reaching 50 degrees.
car back to volkswagen dealer as we do not have an Audi dealer in town. They changed out the Tthermostate. Still afterpaying 1000 £ problem is still not solved in fact temp was closer to 50 degrees.
Have now tried Audi dealer in neighboring thry did not solve the issue either, but identified air i the cooling system , which was removed, temp is dlightly better mac 70 degrees.
Still need to have the car back to dealers work shop, but uncetainif they are able to identify problem. Computer checks are not i dentifying any faults
any ideas?
Old 04-24-2018, 03:18 PM
lentiman's Avatar
Hi Arne, can you include some information on your vehicle: year, engine, kilometers, etc.?
Old 04-24-2018, 06:27 PM
Q7 3.0 TDI Exclusiv
manufactured May 2010
Old 04-24-2018, 08:59 PM
105000 km
Old 04-24-2018, 11:44 PM
dreadlocks's Avatar
has it been especially cold lately? If radiator fans peg at maximum all the time a diesel can really struggle to reach operating temp when facing sub-freezing temps.
Old 04-25-2018, 12:26 AM
We had a periode down to - 30 just after service
however now temp 10+
Old 04-25-2018, 01:54 PM
lentiman's Avatar
Are you determining the operating temperature via driver display? My 2015 TDI runs at about 100C at operating temperature. Does the temperature gauge never reach mid-range? Do you see any change in operating temperature now that it is warmer outside?
Old 04-25-2018, 07:06 PM
Temperature is still low as seen on the gauge in instrument panel . Normal temp previously was 90 degrees. With high load uphill temp is approching 90. But drops if load is decreased eg downhill.
Old 04-25-2018, 07:54 PM
dreadlocks's Avatar
have it scanned with VCDS/ObdEleven or Dealer tool..
are fans running constantly even when not to operating temp? Fan Controllers tend to fail in a safe way (ie run @ 100% and not 0%)
Old 04-26-2018, 08:30 AM
I hav checked , the fans are not runninhg continously start snd stop as they sjould according to workshop engineer
Tbone323
Audi A5 / S5 / RS5 Coupe & Cabrio (B9)
02-03-2019 04:41 PM
mikesd1980
09-30-2008 03:24 AM
Umlaut
A4 (B7 Platform) Discussion
10-02-2007 06:04 PM
wustinger
08-23-2002 06:24 PM
94-100CS-inWI
Misc. Models Discussion
11-13-2000 04:22 AM
Quick Reply: Unable to reach correct operating temp
