Coolant leak
Old 09-19-2018, 04:30 PM
zmatania's Avatar
Default Coolant leak
Hello, I have a 2001 Audi TT 1.8t 225 roadster. It is leaking coolant from the passenger side of the engine. The car has 49,000 miles on it. I doubt it would be the water pump with so few miles. Any ideas? Coolant is all over the bottom of the block on the passenger side.
Old 09-19-2018, 06:31 PM
Mister Bally's Avatar
Pull engine covers from the front (pulley side) of the engine to look for a leak in that area. There is one on the top and one on the lower part of the engine.I'd suspect the water pump based on age, regardless of mileage.
A pressure test kit is best to use to find intermittent leaks. Harbor Freight has a decent one for non-shop use.
Old 09-19-2018, 07:08 PM
zmatania's Avatar
I pulled the timing cover today, I didn't see anything from the water pump. Doesn't mean its not that, but there wasn't any fluid under the cover at all that I could see
dorsal900
12v V6 Discussion
10-03-2008 01:09 PM
MBL2.7t
08-26-2005 11:46 AM
X-Tonic Tiptronic
08-17-2004 11:58 AM
phatpaddy
04-01-2004 03:42 PM
huwla
09-17-2003 04:38 AM
Quick Reply: Coolant leak
