Heating Issue?
Heating Issue?
I am wondering if anyone has experience this.
When I first start the Allroad after it has been sitting overnight I need to leave the interior temp setting on “High” for the first 45-50 mins of driving in order for the interior to heat up. If I set the temp control setting to any other setting the vents blow cool (not cold) air.
For example, after driving for approx 20 mins on several occasions, I lowered the temp setting to 84 degrees and the vent would still blow cool air. Only after driving for approx 45-50 mins am I able to lower the control to 84 and receive heat. In addition even after driving for 50 mins, if I try to lower the temp control to anything below 80 degrees it blows cool (again not cold) air.
On a very cold morning I lowered the temp to 74 degrees after driving approx 30 mins and within 2 mins the interior windows fogged up. And no, the recirculate system was not on and it wasn’t raining outside. It's frustrating because on our Q7 after 15 mins I can't keep the temp setting over 73 or the interior gets too warm.
I put a call into service and while awaiting a response figured I would ask.
Thanks.
Thanks.
Thanks.
Thanks.
Yup, my thought's exactly, I'm bringing it in on Saturday and plan on leaving it for several days..
Funny thing is I only experience this on the first engine start of the day after the car has sat all night. Even yesterday after having the issue on my drive to work in the morning, got in the car 9 hours later to go home and the interior warmed up normally within 10 mins and was able to keep the temp setting in the 70's and received heat.
i live about an hour away from the dealership. So i am making a list of items, to get looked at during my next oil change so i can get everything at once. For now i am using the heated seats/ wheel to keep self warm and it works great. but it would be great to know if it is something they can resolve and if it was under warranty. thanks!
UPDATE:
Fortunately the service technician was able to duplicate the issue exactly as I described it, when the temp was set to anything but "High" it would blow cool air..
The tech found that one of the coolant hoses was severely pinched, and he also noticed a slight coolant leak around the thermostat housing.. So he replaced the hose, installed a new thermostat, flushed and replaced the coolant and now everything is working as it should.. Finally I am getting heat with the temp setting in the 70's ..
I'm not kidding, I was getting ready to hear the usual they found nothing wrong and it was "operating as designed".. Which would have meant more trips back and forth to service.. So I was pleasantly surprised when I got the call and was told what they found...
Stu
9
11-07-1999 08:41 PM
