I need help with my 97 audi a4 aeb 1.8t
Old 05-20-2019, 07:07 PM
Daniel A. Martinez's Avatar
Default I need help with my 97 audi a4 aeb 1.8t
Hi, i recently did a coil conversion kit & icm delete(plug and play) because i was having missfires. After doing the conversion kit, i took it for a text drive and after a few high revs and geting back to the parking lot, the car shut off. It cranked but wouldnt stay on unless i throttled it. I decided to do a throttle bottle cleaning becuase it was rough idleing when i would try to turn it back on. Unfortunately i didnt know i would have to do an adaptation. I took it to mechanic and they were able to do the vagcom adaptation but that didnt solve the issue. Now it doesn throw codes and it starts, idles for a second or so then shuts off. It does stay on if i throttle but it sounds like its clogged or something. Im at a dead end and dont know what do to. Thank you
Old 05-21-2019, 04:37 AM
clancy's Avatar
When was the fuel pump replaced?
Old 05-21-2019, 03:08 PM
Im not sure tbh, it was sitting in a truck lot for a year or so, and then i got it back on the road and it was driving fine for a few months, until i let it sit again for a couple of months
Old 05-22-2019, 05:16 AM
clancy's Avatar
What was the reason for the coil change? Did the problem begin after this change? Do you have the old parts?
Old 05-22-2019, 09:29 PM
i did the coil change because i already have two pairs of fsi coils.So i just got the conversion kit. Which fixed the missfire issue i had. The problem began after i took it for a test drive and and i slowed down, it shut off on me. Before the test drive, i was revving it and everything and it didnt shut off. I do still have the old parts, but when i re installed them, the car just cranks. but it might be because i re installed the old coils but not the icm(cuz my cousin tossed it like a dummy)
Old 05-23-2019, 07:05 AM
clancy's Avatar
Just trying to figure out if the new coil setup caused a new problem or just changed the character of a previous problem. Or if you just now have a new problem.
Old 05-26-2019, 10:47 AM
The new coil setup is the plug and play from ecs tunning. It came with new spark plugs and everything, the only thing that i already had where the coils
nrgglider
07-05-2018 12:53 PM
candybuddy
A4 (B8 Platform) Discussion
12-28-2017 07:22 AM
Xiety
03-12-2004 10:10 PM
BulleTT
08-28-2000 01:39 PM
Quick Reply: I need help with my 97 audi a4 aeb 1.8t
