P164E00 Code
Old Jul 10, 2020 | 03:43 AM
AudiMaster Tech's Avatar
Default P164E00 Code
2013 Audi A8L 4.0t. No check engine light but have one active code that won't clear. Anyone have experience with this? It says Oil pressure regulation valve electrical error. Thanks for the help.
Old Jul 10, 2020 | 05:42 AM
Sawdusty Dan's Avatar
Found a few references to this code on other sites. Most are associated with either a recent oil change, or mods done to the car. Do either of those apply here?
A few did say they 'fixed' it by cleaning and/or re-seating the oil pressure sensor connectors, near the oil filter.
Old Jul 10, 2020 | 05:44 AM
Alex Kap's Avatar
I did have a oil change done about 2 months ago. Car is stock. Guess I'll check the oil pressure connectors. Thanks for the information.
Old Jul 10, 2020 | 07:39 AM
MP4.2+6.0's Avatar
Tech Guru
"P" Code reads like OBDII generic scanner. True? If so, try VCDS or equivalent and see if that code info in VCDS/Audi speak is more specific. Searching via those codes can also yield better results specific to Audi's and the given motors.
Old Jul 10, 2020 | 02:02 PM
It was a Autel scanner. I'll give VCDS a try my co-worker has one.Thanks for the help.
Old Jul 16, 2020 | 12:54 PM
gk1's Avatar
gk1
P164E00 Oil pressure regulation valve Electrical malfunction
If it's not the wiring or loose connectors, maybe try replacing the N428 valve.
Might have to move the A/C compressor to get to it. Should be lower driver's side of engine block.
06H115243M
https://www.ecstuning.com/b-genuine-...ve/06h115243m/
Old Jul 16, 2020 | 01:00 PM
06H115243M
Thanks a lot for the information and part number. Its very helpful! Will there be any negative side effects if its not working? Not sure how long that part has been bad on my A8.
Old Jul 18, 2020 | 12:16 PM
gk1's Avatar
gk1
NP. Honesty...don't know...thought you would know "AudiMaster Tech"
Since it is an actual valve and not just a sensor my assumption is oil pressure may not be regulated properly which in general would be overall bad, but perhaps it has a built in fail-safe so it faults to the side of less engine damage...kinda like thermostats which fail open instead of fail closed, but I don't really know. GL
 Michael S. Palmer
Old May 17, 2022 | 01:59 PM
AndreiZumbaS3's Avatar
Hi! Did you solve it? I have the same error on my 2017 Audi S3
Old Jun 26, 2022 | 04:35 AM
JimboBlue's Avatar
I also have the same error code showing up on OBDEleven reader for my 2018 S3 with no other symptoms or issues, it would be interesting to know the outcome of this
