PDA
View Full Version : Audi Q4 e-tron
  1. A14 battery replacement?
  2. Android auto keeps disconnecting
  3. Audi Q9 finally brings matrix headlights to the US
  4. There' a lot to like about the facelifted 2027 Q4 interior but that Virtual Cockpit!
  5. (GUIDE) - QQ9 Ambient Light package retrofit
  6. Retrofit a heated steering wheel.
  7. Q4 e tron headlight parts
  8. Magnetic phone mount options
  9. Q4 e-tron - no RDS
  10. Vehicle totaled/without warranty on new Audi q4 purchased at 27 miles
  11. 2023 Q4 e-tron computer loses its mind
  12. Winter cold and emergency charging rate
  13. Matrix LED headlight misbehaviour
  14. 2025 Audi Q4 e-tron 45 Premium Plus (3200 miles)
  15. This function is not available while the vehicle is moving
  16. HUD RANDOMLY TURNS OFF
  17. Audi UTR Front Dashcam Mounting
  18. New to Audi and Evs - Just got 2023 Q4 Sportback Etron in Pebble Grey - wheel questio
  19. Supercharging on Tesla Network
  20. Freon Refill & Refrigerant Recharge
  21. parallel parking
  22. CARPLAY ISSUE
  23. pre sensor safety issue
  24. Communications module issues
  25. Tire feathering on Q4 e-tron
  26. brake unit software recal - 2022 Q4 eTron Premium Plus
  27. Random Loss of Power
  28. My Q4 always charges 5% above the target
  29. Recall #93FR Charging system fails
  30. Wiper blades
  31. 2025 Q4 Sportback e-tron Premium Plus Break issue
  32. Unplug 12V power outlet from center arm rest
  33. Replacement Key Fob 2024 Q4 Etron
  34. Audi q4 only charging to 62kwh
  35. Weak steering wheel heating - Can any adjustments can be made?
  36. Pulsation issue with regenerative braking
  37. Q4 etron troubles / car shutdowns real and widespread than Canada?
  38. 99 MPH!! About to buy then saw this! WTF?
  39. Problem with Audi wall charger?
  40. Charging Time Window Setup
  41. 2024 Q4 Etron Sportback
  42. Navigation/Route Planner
  43. Changing out 12v battery - is their any reprogramming involved?
  44. Q4 programmation stopped working
  45. warranty extension (USA)
  46. Heated steering wheel function barely heats. Normal?
  47. Q4 e-tron Premium Plus Tires
  48. MMI stuck on startup screen "Loading the system. Please wait ..."
  49. Share: How to retrofit Capacitive Steering wheel on a Audi Q4 e-tron
  50. NFC Q4 open with digital key
  51. Toll Transponder Location on Heated WIndshield?
  52. Would I get a Q4 e-tron again in 2 years? It depends
  53. Front Passenger Headrest Removal
  54. HK: Does anyone sucessfully activate the High Beam Assist on a normal LED Q4-E?
  55. Syncing Android with a 2024 Q4
  56. Audi Q4 35 - 2022.
  57. De-energizing
  58. Max AC Blinkin Gremlin
  59. Anyone done the 93R3 charging cable replacement/software update?
  60. NOTHING gets SAVED in Q4
  61. Anyone change the glovebox bulb to LED?
  62. Q4 Matrix LED Headlight Activation Information...
  63. MMI reset
  64. Any particular reason this forum seems completely dead?
  65. Unable to login to MMI
  66. Anyone purchased an MMI Theme as background?
  67. “Your mobile device is still in the vehicle”
  68. Q4 Performance
  69. 160-mph speedometer on a car with top speed of 99 mph?
  70. How to "Activate the Drive System"
  71. Climate control buttons not backlit
  72. Favorites radio station deleted
  73. Couple of features I wish my 2024 Q4 50 Prestige had
  74. Cruise control stalk is not backlit at night. Normal?
  75. Battery software up date warranty recall
  76. New to Forum - Colorado Lease Special 2024 Q4 50 Sportback
  77. Oddly shaped plastic pieces in cargo area of new Q4 e-tron
  78. Dog Mode/Camp Mode
  79. Charge timer switching itself on
  80. Plug and Charge
  81. Audi Q4 - MMI screen on black
  82. Audi Q4 e-tron 50 2024 Quattro Capped LvL3 DC Charging in winter?
  83. Audi Q2 etron won’t start after accident
  84. Compressor "4G0 816 797 F" - 2019 E-Tron Issues?
  85. Change virtual cockpit options
  86. Charge stuck on initialize
  87. Cabin temp on myAudi app?
  88. Minimum Charge Setting?
  89. Q4 Electrical System Malfunction
  90. Need some help Q4 Range
  91. Level 1 Charging
  92. Any known instances of motor failure on Q4s?
  93. Rear brakes on US market Q4s?
  94. Charging system malfunction
  95. FitCamX Rear Traffic Cam Install?
  96. Fuse # for Connecting DashCam (Always On Parking Monitoring)
  97. e-tron “Quattro”
  98. Regen braking keeps activating
  99. smoked bu a BMW suv?
  100. Could the 2025 Q4 e-tron arrive earlier than usual?
  101. Anyone running wheel spacers on 2023 Q4?
  102. Wrong forum 😁
  103. Beware the Heat Pump!
  104. New motor for 2024 !
  105. New Q4 e-tron owner
  106. Snow Tire from Q5 fit Q4 e-Tron?
  107. Lost communication
  108. Changed my mind about getting a Q4 e-tron 50 for now
  109. User settings, and the convenience key
  110. What is “base carrier bars & storage bag” $400 Prestige option?
  111. Heat pump, HUD and other Prestige features
  112. Almost ready to buy Q4 sportback. What do you like the most? Dislike the most?
  113. ChargePoint App Issues
  114. Where to charge.....
  115. Chargepoint Home Flex- Q4 issues?
  116. Parting Ways... Needs to go
  117. New owner questions- phones, keys, multiple drivers, oh my!
  118. Leaving cell phone inside- no audio warning
  119. Radar Detector Install
  120. 2024 models questions
  121. Charger prep.
  122. Electronic issues 2023 vs 2022
  123. 2023 Q4 Etron vs Q4 Etron Sportback Dimension
  124. Audio stays on even when driver's door is opened?
  125. Key User
  126. Seat Belt Latch
  127. UK: 22” Alloys on the Q4 etron
  128. Avoid it.
  129. Model Y or Q4 e-tron
  130. Q4 e-tron. Power Managemnt
  131. audi q4 etron
  132. Audi Q4 Inner Door Handle Compartment Box set of 4-pcs
  133. Durable seat surfaces
  134. rear camera night vision just suuuks
  135. UK: Wing mirror Housing Trim Frame
  136. Finally...
  137. New Model - Q4 e-tron Parts Section is Open...
  138. Lock/unlock via myAudi app
  139. No heat pump
  140. Tesla Pricing
  141. UK: My Q4 a year on.
  142. Audi armrest storage box for center console
  143. Car scanner and Audi q4 support
  144. Display all chargers on nav map?
  145. Q4 Charging
  146. Matte black vs piano black
  147. My Audi app inaccurate
  148. Another MSRP bump?
  149. DK: Low Batteri - Alert? ( Not in manual )
  150. Audi Q4 etron out rates the Tesla Y
  151. Q4 Inventory?
  152. Black rings for the front grille?
  153. Rear bumper protector?
  154. Welcome our new Q4 Sportback
  155. App showing different range
  156. Best highway speed for max range?
  157. Electrical system malfunction
  158. "driver availability recognition" message
  159. First month with the Q4
  160. Genuine "Quattro" Puddle Lights Are On Sale!
  161. Q5 to Q4 etron
  162. Air Conditioner Malfunction
  163. Q4 Ordered!
  164. Q4 NA Hitch Size
  165. Android Auto Connection Issues
  166. Q4 black badges?
  167. 2023 pages and configurator are up for the US: Higher prices, fewer features.
  168. Saturday q4 sightings
  169. Q4 e-tron First Drive Review (AudiWorld Official)
  170. Doug DeMuro review: "it's fine"
  171. 18" winter tires?
  172. EQB is at US dealer lots now
  173. HR: Q4 e-tron
  174. Possible Future Tax Credit for Q4?
  175. Out of Spec Dave Q4 e-tron review
  176. Q4 e-tron - No Rebate
  177. US dealer sites showing demo cars inbound from port
  178. Audi Connect Key and Audi Connect Navigation - Licence Renewal Problem
  179. My Audi App lack of functionality on W4
  180. e-tron model/naming smorgasbord
  181. Audi Q4 Commercial
  182. Premium Plus, Prestige, and quattro options disappeared from US market configurator
  183. Q4 e-tron Sportback configurator has gone live in the US
  184. Spare wheel location?
  185. Cooled seats?
  186. Q4 heating steering wheel
  187. Q4s were supposed to be at the LA Auto Show.
  188. Q4 Range
  189. Q4 vs genesis gv60?
  190. ID.4 dual motor - 5.4 sec 0-60
  191. Federal tax credit vs rebate?
  192. Q4 Delivery Date?
  193. Homelink?
  194. CarPlay?
  195. 250kWh included — how much is that really?
  196. Will USA Q4's have a Heat Pump?
  197. US Allocations and Order Guides?
  198. NL: help with understanding Q4 suspension options
  199. How the Q4 e-tron handles regenerative braking
  200. Q4 Review
  201. Q4 etron lands in the US
  202. US Configurator finally available
  203. Will there be only 4 colors available in the US?
  204. Where is the Q4?
