View Full Version : Brakes Discussion
- Advice appreciated.. need new pads at 42k.. but don't want to be ripped off
- Stoptech rotor hat pins will NOT budge - recommendations?
- Went through the ETKA... question now, will the B7 RS4 Rear brakes fit the A4 1.8TQM?
- Does anyone know what the factory fitting size is for the steel front brake line fitting?
- S4 2001 brake change cost $1000 reasonable or not?
- where to buy PBR Ceramics for 96 Audi A6qw? Should I call MikekiM@PureMS?
- Rear caliper question (after taking it apart)
- Where to order Carbotech XP-10 brake pads from?
- Noob question - start with pads or go for full brake replacement?
- Another Brake Pad Wear Alarm Question - How does it work?
- Anyone have experience with Akebono Euro Ceramic pads? (Tirerack)
- Brake pedal creaking
- Mike from PureMS... what pads do you recommend for a '98 A4 1.8T...
- 01 a4 brake noise! help!?!?
- tt 3.2 brakes
- Brake Pad Wear Alarm and Brake Chime
- I know it's a tired topic (brake squeal). But my case is unique... looking for thoughts/ideas...
- need to know the bolt size of our brake line....
- brakes
- Anyone know where to get HP2 caliper dust caps? Or have a pair they'd let go for cheap?
- Sig...
- Any feedback on Mintex C-Tech Blue track pads?
- B7 A4 first brake pads change.....is rotor change necessary too?
- Looking for replacement of OE Rotors B5 S4 Avant.
- Is the offset of the rear rotors different for B5S4 vs B6 & B7 S4s?
- ABS BRAKE LIGHT!! Came on, HELP : (
- trying to bleed my brakes, when I open the brake fluid reservoir, there is a filter screen inside,
- Tips / Thoughts on how to cure uneven pad wear?
- Any options for aftermarket pads for a C6- A6?
- RS6 brake system on 4.2L...possible ??
- BBK: Porsche Cayenne calipers and rotors question (Audi A4 B6-B7)
- Kudos to StopTech and Zeckhausen Racing for helping me out
- $225 - reasonable labor price to change my 4 rotors/pads? right parts?
- Best all around brake pads for 02 a4 3.0?
- 2000 A6 2.7T.. Front Rotors?
- Best Brake Pads for A4 2004 Quattro 4 cyl
- Rotora Mini Caliper kit
- cross post stoptech 355mm's...
- Breaking free a seized bolt
- Help ESP Light on following rear brakes job. 2002 A6
- Help Needed with Braking Problem....PLEASE!!!
- first audi with ABS
- B5S4:Intermittant display warning. Stops from 30mph & above = Pssshhhhhh sound. <more>
- Quick question, search didn't return much info. I am installing ECS slotted rotors..
- anyone have a clue when stoptech will release ceramic brake kits?
- S4 to A4 brake swap questions
- anywhere I can get a single ST-40 caliper for my 355 kit, aside from StopTech?
- brake noise when coming to a stop
- Paging Bremboguy...
- Brake bleeding
- BBK - Rears
- brakes
- Noisy breaks after replacement
- question for the B5 S4 Brake gurus... failure question.....
- Quick Question...
- APR is proud to announce our new braking upgrades for all late model Audi's and VW's!
- will 04 TT v6 caliper carriers work for the big brake upgrade?
- I just got a set of B5S4 calipers and want to paint them, is it ok to soak/submerge the calipers in
- is there really any difference in rotors between quattro and FWD Audi A4 1.8T?
- Install problem - ATE PremiumOne rotors
- Ongoing brake issues..I cannot bleed my master cylinder
- Carbotech Bobcat Brakepads
- ABS FAILURE
- brakes and roters
- Brakes
- Could someone explain why slotted rotors are better than drilled for track use.
- Very pleased with my 332mm StopTechs + PFC-01s after Road Atlanta
- Any problems swapping between standard and ceramic pads?
- I have squeaky rear pads "mintex red box" any suggestions
- Does anyone know if there is a difference in Rotor offset between the OEM B6 A4 1.8T and the Alcons?
- can you repaint bbk or powder coat them? I wish i had taken a picture.
- thinnest caliper alcon 4pot or stoptech?
- TT caliper carrier question
- Stasis/ Alcon BBK question...
- Rear Pad debonded from backing plate, fell out...
- Where do I get Stoptech 332 replacement disks for a good price?
- Help with troubleshooting brake problem.
- BT: PFC-01s?
- question for track use
- Failed ABS module
- Stripped threads for outside bleeder in ST40 caliper...am I fuxord?
- Which brand carry 245 x 10 slotted rotors?
- where to get a good price on Ferodo or Pagid pads?
- looking to go from axxis ultimates to the carbotech bobcats since my axxis pads are shot.
- 355mm BBK on a 17" wheel?
- Where can B5 S4/Allroad Porsche 993TT Caliper adapters(Brackets) be purchased?
- Doing brakes on A6 for first time
- Daily driver pads, less dust than stock. (b5 avant 1.8T) Axxis? EBC? Pagid? Hawk (expensive!)
- Brake Fluid Reservoir looks like it's cracking on the side towards the windshield....
- GreenStuff pads,, first impression....
- brake booster
- brake issue (99 A4Q)
- Replacing the Master Cylinder
- Anyone install a larger rear disk on a4 3.0 ?
- *popping* on new stoptech kit
- Brake Fluid? Any difference?
- HP2 calipers vs ATE calipers
- Question regarding breaking-in StopTech kit
- Break pads , rotors??
- Do I need to upgrade my rear brake lines if I'm doing a front BBK?
- How do Hawk Ceramic pads compare to their HPS pads?
- upgrade but not bbk
- Locking Breaks
- Swapping Pads & Rotors - ->
- Ferrodo DS 2500 or BHP XPS for Stoptech ST40's Street.
- Brake Rotors 02 audi A6 2.8L Quattro
- Question on brake type on 03 A4 1.8T CVT w. Sport Package
- Brembos without drilled rotors?
- ABS Module not communicating
- ABS Speed Sensor opinion requested
- s4 rear brake calipers piston hard to turn in
- I figured I will ask the Brake forum 1st since we have one.
- Paging BremboGuy...
- Anyone with experience with ECS Rear BBK or the Caliper Bracket?
- Replacing Brake Light Switch (1999 A6)
- BBK install cost
- Ferodo DS2500s vs. Carbotech Bobcats. For my 332mm stoptech fronts. Hard street driving. Fight!
- pads recommendation please
- ESP problem.....
- T/F: Bigger rotors increase stopping power.
- Help finding brake ducts that hang down below the car for cool air.
- torque spec for stoptech ST40 bleeder screw? seem to be leaking small amt of fluid out the top...
- Calipeer Rebuild Kits
- whimpering, crying, squeeling... like a pig.
- Shuttering, pulsating, chattering
- best value brake upgrade?....
- looking for a reply.
- Pinging / Crunching sound when apply brakes
- Is it a super terrible idea to use a 321x31mm rotor with a caliper that is meant to use a 321x32?
- Can I resurface Stoptech rotors?
- Racing brake pads: your favorite?
- Question regarding brake disc preformance
- Electronic Stability Protection--Always on, or only in dicey conditions?
- Looking for advice from you experts!
- Need to replace Stoptech rotor rings...any reason NOT to use these??
- Brake Pads?
- Porterfields on a b6S4...anybody use them for HPDE's?
- break lights not working and car does not come out of park when you put break on
- On a B5 S4 - What rear brake solutions would go well with B7 RS4 fronts ?
- Audi A6 Brake problem on snow
- 2001 Audi TT front brake problem, need help/info!!!
- Help Eliminating Brake Noise
- Help with brakes......please....
- X post from B5 A4 forum
- XPost from A6 (C5): Low Brake Pedal
- Just Bought some new Hawks Performance Brakes for my Audi A6
- ECS Stage 4 braking for B7 S4
- Better braking without going BIG BRAKE?
- Any Movit brake owners here?
- A revolution in braking! (awesome!)
- good pads to use with Stoptech ST40 and 355s on B5 S4?
- TT Rear Brakes
- other than ecs....and porsche where can i get a rebuild kit for my 993 tt brake kit?
- thoughts on Axxis Ultimate pads for daily driver and light track duty (not on an Audi)
- Stoptech owners...would anyone be interested in trading ST40 calipers?
- how can I get the caliper bracket for my b5 1.8t to install the 993tt brakes
- Replacing rear brake rotors on B6 A4
- ryoung - can you provide your thoughts and experience with the Carbotech bobcat pads?
- 2002 A6 Soft Pedal (LONG)
- so i am rebuilding a caliper and need to make sure i have the right caliper grease
- Those with Stoptech BBK, do you remove for harsh winter driving?
- HP2 calipers vs stock single piston
- Brackets to fit B5 A4 Brembo BBK on B5 S4?
- Need advice on pad deposits forming on Stoptech rotors on the track.
- Looking at G2 Caliper Paint System..Opinions and questions....
- Brembo Brake Install and Impressions on 2006 B7 A4 2.0T
- Rear brake pad replacement. HELP!!!
- Electronic Wedge Brakes...in 2008 Audis?
- ABS run for no reason on 2001 A4 2.8Q 30V
- looking for absolute best cold bite, don't care about dust
- need recommendations for brake pads...
- Any one ever used this system?
- This weekend I will be rebuilding one of my B6 S4 brake calipers, while i have seen it done I have
- Can you powder coat stoptech calipers? Many have said no. Anyone beg to differ?
- ReAr RoToR iSSue? Audi A4 B5 2.8Q 12v
- Dealer states to stay away from after market brakes!?
- Good source for bolts to mount 993TT rotors to ECS hats? ECS does not sell them seperately.
- Looking for flat black paint to do my calipers with, i was thinking just a high temp engine paint
- Porsche 993 Kit
- Porsche Boxter S brakes on a B5
- is it ok to run a caliper designed to use both a "weather seal" and inner seal
- Painting calipers question.>>>
- Is running 309mm discs up front & 288mm discs in back risking brake in-balance?
- Question: When replacing rotors-rings and hats for Brembo Grand Turismo kits, can one purchase
- Details regarding brakes and work procedures
- Super inexpensive rotors and brake pads. Too good to be true?
- Movit brake hat height about 17mm for there 993TT BBK fronts. any idea on ECS or BIRA??
- About my Brake light.......
- North American source for a 288x15 rotor?
- Need new hat for 993TT BBK. Old hats are broken from fatigue.
- Will Stoptech 332s fit behind the 17" avus wheels on a B5 A4?
- Compressing caliper
- does ferodo make a 2500 pad for rear b5 a4 caliper fitment?
- my (on going) quest to solve brake heat problem...
- Changing ABS ring on Rear Brake Rotors
- Anyone had problems with ECS Stage 2 V2 rotors hitting the ball joint on the lower control arm?
- Very little brakes after line replacement
- ABS Issue
- b6s4 help..x post
- What 3rd party brakes can I fit to a 2004 B6 S4 without using spacers on 18" OEM wheels?
- B6 3.0 front carrier part #s?
- ABS LIGHT AND FLASHING BRAKE LIGHT
- front pads for 2002 allroad (2 pad setup)
- ESP Control Module
- X-post Re: Mintex Brake squealing
- I want to upgrade my rear brakes.....................
- Raise your hand if you at one time installed a brake pad in backwards?
- ABS/ESP Control Module
- List of wheels that clear Boxster/TT225 312mm rotor setup FWD/AWD A-Chassis
- rear brake pedel judder
- DIY Wheel Bearing attempt with Harbor Freight $80 kit? possible?
- Grinding/Pulsation from Front when braking HELP PLEASE!
- Front Brake Rattle
- Switch to S4 calipers.
- Are the B6S4 and B7 S4 brakes the same?
- Removing Rotors on 01 S4.... RANT....
- Rusting Rotors Solution..........
- StopTech to Brembo Switch (Alcon comparo as well)
- 1st time for me do'n a brake job.... 01 TT
- soft pedal after pad/rotor (stock size) swap test drive, suggestions?
- b6S4 front oe pads fried at WG...any suggestions (other than driving style)?
- So, I have these Boxster Calipers lying around...
- ecstuning oem brake upgrade
- Offset?
- Rusting Rotors.......................
- STFA. Can't get my brakes to stop squeeking
- Akebono Euro Ceramic or PBR ceramic brake pads for 2001 S4?
- anyone with a bentley manual for B6 A4 know torque specs for front brakes upgrade?
- can't get rid of squeeks on my new front rotors and pads.....
- Paging Randy
- Bleeding order - traditional vs. A3 Bentley CD
- Weird Problem With Brakes.... Please Help
- Trying to get rid of brake squeal...................
- Rotors seized on hub
- 'Bendix' front brakes for tt FWD
- How to Bleed Brakes with Air Compressor
- Noise on Hawk HPS?
- my brakes seem to have a very light pressure on them
- New wheels and brakes - something is not right.
- Front and rear rotors?
- Are there any real tests made that would confirm Stoptechs > HP2s? Just curious
- Rear brake caliper piston
- Anybody warped stoptech rotors b4?
- Suggestions on brake upgrade for my TT... (non-track)
- Need a break job, rotors and pads...
- Looking for some suggestions
- Brembo 332mm kits are now available for B5 S4, and B6/7 A4s.
- B5 S4 BBK at the track: anyone ever overheat a 13" setup? I have heard from
- does anyone make a big brake kit for B6's using regular (non-turbo) 993 calipers?
- Minimum Rotor Thickness for '01 TT???
