View Full Version : Brakes Discussion
- 1995 A6 Quattro Brake Failure, after driving through a puddle.
- Dealer says I have to get rotors and pads for an S6
- yet another vibration issue
- rs6 brakes on A4 b5
- CERAMIC BRAKES
- "Normal" brake pad wear?
- Sensors in the front brake pads
- Brake Failure
- New StopTech Trophy Sports Look SICK!!!
- need brake rotor and pad opinions for audi tt
- Help!! 01 A6 Brake caliper removal
- Audi A4 2007 Brake Fluid Problem
- Rebuild a 2-piston Lucas/Girling front caliper???
- Rear Brake pads
- Porsche 996/boxter s monobloc caliper- pagid blue part #
- A6 rear rotor carrier binding
- Looking for Brake Disc
- Fixing Brake Judder?
- Brakes thread - imagine
- Need New Rotors
- brake light out
- Looking for Brake Discs
- Audi A6 3.0 Quattro (2005)
- Fluid leaking out caliper seal & brake noise?
- New Car Purchase Question
- ABS Light
- I need a new floor jack...
- brakes
- Abrasive sound heard on hard braking
- Brake Fluid
- Large brake pad chamfers - why?
- Anyone here own the MOTIVE POWER EXTRACTOR from ECSTUNING? What are your feelings about it?
- Wow...this place is dead...just put some Hawk HP Plus pads on my miata
- Does anyone have the bently's direction for changing the front wheel bearing on B6 A4 Q?
- Vibration in steering wheel when braking. Warped rotors???
- ECS 2 piece slotted rotors
- Serious pad selection help needed. <Long>
- Problem running ABS pump using VAG COM
- Any suggestions of where to buy PRC01's for Stoptech ST40's in Orange County, ca
- Brake Fuild Replacement VAG-com?
- Air Leak (maybe?) in Hydraulic System after work '91 Audi 100
- (HELP) Whistling sound while parking
- IS it possible to bleed the brake lines the old fashion way on 2005+ A6 models?
- Anyone happens to know what the offset is on the B5-S4 front brake rotors ? TIA.
- Lost rear passenger tire at 50mph and lost braking! (B6 1.8T) Any ideas?
- New Rotors/Pads 15K ago- now vibration when braking?
- HPS same pad as Posi/Centric ?
- TT MkII Brake Squeal
- Can anyone tell me what if I should buy upgraded rotors my 03' A6 2.7t?
- rear brakes
- Help! My LR brake is smoking!
- Will it fit?: 349mm Alcon Rotors w/ Stock B7 Caliper Clearance
- Need some Help! 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
- Can anyone point me to a good Pro Caliper Painter / Autobody Shop?
- 1 StopTech 355mm ST40 BBK in yellow available at a great price from Achtuning!
- need new pads for 05 A6 C6
- Looking to trade entire Boxter brake kit (lightly used) for stock(ish) B5 set-up plus cash.
- Xpost: 2005 A6 3.2Q What size is required to remove quide pins?
- rear brake lines
- R&R'd all 4 pads, rotors. LF rotor gets warm & smelly now from normal driving.
- Spongy pedal after Hawk Ceramic and ECS Slotted Rotors
- Retaining (anti-clatter) spring for front disc on 2005 A6
- Need some quick information on reinstalling fromt spring A6 brakes
- brake servo needed 1994 s4
- ABS warning light
- Other alternatives for brake pads for Alcon brakes?
- Which 2 pc Brembo Rotors Part # ?
- How can I get the piston out of a caliper?
- Is rust on "new" brake rotors a problem ?
- Possible problem with ceramic brakes - now with pics
- 2004 A6 2.7 T - Brake pads and Rotor change.question
- Rear brakes 1999 Audi A6 Avant help
- Can StopTech 332x32 front brake kit clear Flik Justice 17" wheels?
- From bad to worse! (long)
- Brake job with ESP?
- can I run B5 S4 7.5x17 wheels on a stock 2001 S8 (brake clearance, etc)?
- rear brake pad and rotor replacement help
- Can I change my own brake pads
- Jutter problem....advice needed. (a bit long)
- Some pictures of new BBK on the S5
- Anyone know the proper torque spec for 2006 B7S4 carrier bolts.....
- carbotech performance brakes
- Can't get front calipers off my allroad...
- 1999 AUDI A-4Q 2.8L BRAKE ISSUE
- Performance Brake Rotors by DBA
- Should I be happy with this setup: JIC/AN stuff
- Brake Pad Problem HELP!
- Brake lamp beeping doesnt stop with new lamp...
- Alternative brake pads to fit Alcon BBKs?
- Normal for new pads & rotors to make grinding noise/vibrations...(more)
- Severe driverside front brake drag/Need Help
- heat shrink for braided lines?
- Small tear in rubber boot covering rear pistion... Should I replace the boot?
- Hawks HP+ pads overheating on favorite road...am I driving wrong?
- Best source for Ferodo DS2500 pads for Porsche 996 monoblocks?
- Bedding rotors vs pads - Instructions conflict???
- how can I improve brake pedal feel?
- Anybody with brake squeal issues on a Q7?
- Brembo Gran Turismo BBK Specials!
- Help, please: what rotors/pads for my '03 A6 2.7T
- AP Racing Radi-Cal Calipers...Anyone use these before?
- What's the consensus here on the EBC Redstuff superstreet pads.
- Noise coming from new Stoptech kit only during throttle/coasting??
- Track pads for an '04 S4 V8
- replacing front rotors
- My ABS is goosed
- 996 BBK BT? Help!? I have one caliper....
- Brake help
- Slight squeaking at 46,000 miles
- Help diagnosing brake problem
- Has anyone tried DBA 5000 replacement discs for B5 S4.....
- X-post from C6 forum -- is there a size difference between the c6 3.2 vs c6 4.2 rotors/pads? thx
- certified car needs new rotors
- 2001 audi tt quattro 1.8L anti rattle springs?
- front brake pad warning
- 2.7t 2001 C5 A6 ABS module w/ ESP Needing a little help.
- Any thoughts! Stoptech or Porsche brakes for a B5 S4??
- Mintex pads...is there a new type? There seems to be a lot of negative feedback on Mintex pads but
- Anyone know of a place that sells those heat indicators for calipers?
- Need Help....
- How to change rear caliper 01.5 S4
- Are 2-piece rotor hats universal? I assume not but it's worth asking
- Replacement Brake Pads for 2003 A4 (B6)
- new brake pads installednow they don't work
- B4 Calipers
- Are B6 S4 brakes a direct bolt on upgrade for B6 A4?
- Any one running Carbotech pads - the noise is killing me...
- Safety based on radar technology - Audi braking guard
- Opinions please
- looking for B6/B7 S4 rear calipers and carriers. Do any other Audis ..
- Problems with ECS two-piece rotors? Excessive movement between hat and rotor ring?
- Any one running any economic stimulus deals on stoptech BBK's?
- Should the clutch bleed along with the brakes on the B7
- Is VAG-Com needed for a brake flush on B7 A4?
- Floating calipers, ahem, don't ( crosspost)
- Recommended street pads for Stasis Touring package (Alcon 345 x 26mm)?
- 2002 S6 Brake Rotors and Pads
- Stasis Alcons up front and ??? in the rear?
- Think I have a piston sticking..brakes always sweaking...
- Testing calipers
- PSA; Axxis Ultimates suck. Squeal like a biotch.
- Brake Pads for new '08 TTR 3.2
- Brembo rotors are rusting
- Brakes locked! need ideas!
- Choosing between TWO kits...
- Porsche 996/986S Brakes on my B6 A4 - BRACKETS NEEDED
- you have a brillaint yellow A4... what color would you powder coat your calipers???
- so, anyone ever have issues with pressure bleeder not getting air out
- Sqeeeeeeeeeeeeeeeekkkkkkkkkkk!
- Anyone here put Girling 60 calipers on a corrado?
- Brake job boob needs help, brakes won't let go!
- Brake job on my allroad with pics
- Brake Pad Wear Light.....
- What Brakes Pads Should I Get???
- ECS Stage 4 - upside down?
- For Sale Feeler Post! Stasis Motorsport setup for B7 S4
- Paging Gary Cogis the Brembo guy
- APR Rear Brake Sale
- early b6 a4 to hp2 conversion...
- So, who might have the best price on Zimmermann rotors?
- Question for Brembo people
- Question on breaking in new rotors
- Brake carrier bracket help/questions
- Can anyone comment (good or bad) on "Brake Planet " stuff?
- how do I remove the pistons on Alcon type B calipers? I got the special wrenches but I'm still
- Will a 355mm BBK fit with stock 18" wheels?
- First time posting here; Putting HP2's on the allroad and need rotor/pad recommendations
- Any Spring BRAKE sales coming up, anywhere, USA?
- Brakes locked on me today
- brake fluid
- NE1 here using PBR ceramics on a '00 A6 2.7t?
- Review PBR Metal Master VS. Ceramic
- long shot post of the day.. what size are the piston on Alcon type-B calipers?
- With this Brembo kit: 1A5.6001A what would it
- B5 S4 brakes...non-OEM?
- A4 2.0T Stock Brake Replacement Instructions
- X-Post: Slotted rotors = noisier brakes?
- How much Brake Fluid for a Complete Flush?
- Brake warning light driving me crazy!!
- 2000 s4 without esp master cylinder.
- B7 S4 Caliper Question
- Alcon or Brembo 355mm 4pot ???
- Who wants to sell me new BBK Stoptechs for a Audi TT '03 quattro
- after installing and bedding new DS2500 pads i now have a 'warped' rotor sensation
- 2001 S4 Stock Breaks Which Pads?
- Source for B6 or B7 rear brake upgrade for B5 S4 (larger rotors)
- Powdercoat BT: How/what to mask when coating brake parts?
- How should I clean my power bleeder? It's been sitting in the garage for a while
- Mechanic Blames EBC Green Stuff
- In case you have not seen the new Brembo kits.
- Ferodo FDB560 Brake Pads fit stoptech BBKs correct? just wanted a confirmation
- Help bleeding brakes :(
- where is the best place to purchase a stoptech 332 kit for my 04 a4?
- x-post - HP 2 caliper retainer springs
- Where to get new pads replaced around Boca Raton, FL area?
- 2007 A4 2.0T looking for brake upgrade options
- Where should i buy rotors and pads for my 2.7t A6 01?
- Anyone installed big brake kits on their A6 C6 yet?
- Cold weather and E-brakes
- Thunderhill next weekend. Help needed with ESP warning light and limp mode in the rain
- ESP warning light & Limp Mode when raining
- Brake saga
- Question on the 312mm x 25mm rotors
- Braided Brake Line
- Basic Advice on Rotors Please
- where to retail buy Akenobo brake pads in Los Angeles
- 2 day ONLY!!!: brembo BBK, LOWEST PRICE EVER guaranteed SPECIAL!!! 12/20-21st
- Brake Caliper Paint (silver)
- custom rotors for cheap! dimpled/drilled/slotted
- Rusted Rotors and Grinding Brakes
- NEED ADVICE! BBK fitment
- Front right brake squeak
- Lightweight Brake Upgrade for B7 S4?
- Please Help! Stuck Caliper tool!
- Problem with Brembo GT 355, paging Bremboguy.
- 987 Boxster S Brakes on my B6 A4 1.8T?
- New Owner Brake Problem
- noob /brake vacuum pump
- what options are out there for rear calipers for the big girl other than oem replacements?
- Any opinions on the ATE PremiumOne slotted rotors? The ones with the elliptical slots.
- Need new rotors for my '02 A4 Avant...any advice?
- 07 RS-4 brakes failed@13k
- Audi is addressing brake dust issues!
- Vibration/noise help
- Recommendations for brake fluid?
- Stoptech Big Brake Kit
- What would be the size of the brake discs if you use a 19" wheel?
- Help.....
- X-Post from Wheel/Tire Forum...wheels that clear APR/Brembo Stage 3 355mm setup
- Stoptech BBK from a B5 S4 onto a C5 A6 2.7T?
- Help with brake upgrade setup for a B7 2.0T
- Helpless situation!! Please help with installing a new master cylinder in my 96 A6 Quattro
- What color is Motul 5.1?
- B5 S4 has trailing calipers, UrS4 has leading calipers....They are not interchangeable, 4 pot S8...
- brakes for 2003 A4 3.0quattro - some confusion
- Turning rotors
- APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
- Help with Hydraulic Servo Unit Replacement
- noob Q's on performing brake pad replacements on 01 a4 quattro
- Does anyone have the weights of the C6 3.2 FWD brake discs + calipers,
- Brake questions. X-Post from B6 Forum. TIA
- ABS problem-HELP!! Where are the matches???(Long)
- Interested in improving the handling of my C6 by reducing unsprung weight.
- Question about switching pad compounds
- Brake experts: What are the torque specs for the HP2 caliper carrier bolts?
- Cool...got Alcon brakes from StaSIS on my 335i...
- Painting Brakes
- HP2 brakes for older cars link to main thread.......
- Rear big Brake upgrade?
- Anyway to clean these calipers? The bottom half of all 4 calipers have become discolored...
