PDA
View Full Version : Brakes Discussion
Pages : 1 2 3 4 5 [6]
  1. Brake lines are being pains in the butt goin into the caliper...
  2. brake lights
  3. porsche 997 calipers - same as 996 or no?
  4. which is left and which is right??
  5. That annoying screen on the brake fuild resevoir...
  6. DIY Bleeder Pump
  7. trying to make a bleeder pump...anyone know the size of the reservoir cap?
  8. Size of bleeder valve??
  9. crazyness
  10. OK, so I don't know if this is a stupid question or not...
  11. Lookin for 2 good oem B5 small-ear calipers, mine are teh suxor.I have 2 B6 big ones if anyone wants
  12. What other [Porsche] brakes work w/ the B5 A4, and where is the cheapest place to get them?
  13. VW Part question
  14. Rotor advice..
  15. xpost: howto replace b6 rotors and other tidbits (long)
  16. Brake Squeeeel and (O) Light
  17. Replacing rear calipers, are there any washers or anything on the line i need to replace?
  18. how do I drain my brake fluid w/o a bleeder tool?
  19. brembo rotors on ebay
  20. New carriers, rotors, and pads. | Require brake bleed?
  21. How hard is it to remove the brake calipers? Instructions?
  22. Question on mintex red box
  23. Warping the rotors on road course...
  24. x-Post: Brake Caliper painting….how are the long term results?
  25. Brake squeal...it's back; is it the pad backing or the slides?
  26. what is the difference between the A8L and A8 braking systems?
  27. Swapping of front brakes between Passat and A4, will it work?
  28. Does anyone know if the updated front brake shield (8D0 698 998) will fit behind A8 disks? Thanks!
  29. Easy (?) question about rear caliper replacement
  30. Question on Brake Fluid Compressibility ...
  31. Anyone know how to get rid of the "chirp" over bumps coming from the brakes?
  32. Is using Motul 600 bad for our cars???
  33. 5th Annual Audi Expo - Schedule:
  34. frozenrotors vs ECS?
  35. Stop Tech pads for Street/light track use....
  36. Picture of my new brakes (Zimmerman X-drilled/PBR MM pads) along with Motul 600...
  37. 9 days 'til Audi Expo! - Have we heard from you ?
  38. Does Audi use Bubble Flares on their brake lines or Double Flare?...
  39. HP2 caliper dust boot a DIY job, or am I too optimistic?
  40. B6 A4 1.8T Q Brake upgrade question. Your input is appreciated.
  41. My Bro has a '00 B5 S4, what can he do to keep his rotors from warping???
  42. Carbotech Bobcats vs. Stock B6 S4 pads?
  43. Anyone out there have rear brake issues with the allroad?!?
  44. Anyone know how much current an ABS sensor draws?
  45. Can anyone look at a few pics of used rotors/bbk i'm looking at getting, rather email than post pics
  46. 96 A4 FWD rear rotor replacement!!!
  47. XPOST: Replacement Pads
  48. Already STFA - will 18x8.5, ET 32, BBS RC rims fit over Stopetech or other BBK?
  49. Slotted to edge vs slotted vs cross drilled ... what is better for street use
  50. question? about fluid. I just had b5 s4 brakes installed on my b6 a4.
  51. B5 S4: new HPS pads + Valvoline Synthetic fluid went to the floor today...
  52. OEM pads on rear on A4/B6?
  53. 5th Annual Audi Expo - Come be a part of history again!
  54. Anyone know if the carrier bolt spacing is the same for Boxster S & non-S calipers?
  55. Is A8 Upgrade worth it?
  56. How much for full B6 S4 brake kit?
  57. Cross-drilled rotors for B6 S4 factory calipers?
  58. Sales guy at KVR Performance wants me to go Ferodo over Hawk..
  59. '96 A4, can't compress rear piston to get new pads in, help?
  60. Has anyone used Mityvac MV6830 for bleeding?
  61. Painted my rusty HP2 brake calipers today!!!
  62. Worn down pad was wearing a groove into one of my rotors...
  63. Caliper carriers
  64. can someone walk me thru the bleeding procedure for Porsche 996 calipers?
  65. where can I get brembo decals?TIA
  66. Front brake upgrade complete
  67. locating ABS wires
  68. I'm putting stoptechs on my S6, what to do with old calipers....
  69. X-Post from TT Forum...
  70. Looking for B6 S4 rear calipers, and carriers
  71. What are the signs of a dieing brake booster?
  72. Pagid Sport vs Pagid Blue.
  73. does Ferodo make pads for the S4 HP2 calipers?
  74. Where do you secure the ABS wire to?
  75. what newer rear calipers can fit a 93 100cs
  76. Pickup some B5 S4 Calipers.
  77. Are the B5 S4 stock brakes used as an upgrade on any of the other cars here?
  78. faint grinding noise from front brakes on my Allroad.....
  79. 3.0 b6 brakes on a 1.8T b6(a4 cab) good idea or no?
  80. brakes
  81. what is the difference between 996 TT calipers and 993 TT calipers?
  82. S6 (C5) rear brake options?
  83. Can I get aftermarket rotors trued?
  84. Is there a brake pad that generates less dust than OEM?...
  85. HEEEELLLLPPP X-post to A6 Forum!!!
  86. What solvent to use to remove film from new brake rotors?
  87. what size brakes will fit under my 19" rs-gt's?
  88. Brake Pads
  89. Anybody have the ECS Stage 4 Brake kit? Impressions please?
  90. Anyone have a relationship to get Lotus parts at less than retail?
  91. anything i should know before having my alcons powder coated?
  92. running Front ECS stg 4s.Rotors are 352mm. Whats a good rear rotor size to compliment the front?...
  93. Anyone have first-hand experience comparing Pagid Sport Blue pads with Ferodo DS2500s?
  94. brake pads for movit 993 brakes. track use
  95. How much fluid in ABS system?
  96. 993TT rotors and Hats
  97. My AP Racing calipers are 4.5 years old with ~58k miles on them. Time to rebuild them?
  98. Need new rotors
  99. does the B5 & B6 A4 1.8T use the same rear brake pads?
  100. cheapest source for Ferrodo pads please, anyone? i'm in CA...
  101. Question: the 98 a4 has a smaller master/brake booster then the newer a4 or s4
  102. 2000 A6 2.7t in need of front rotors/pads...Any good values out there right now?
  103. A6 4.2 Wheel Lug Torque...
  104. Boxster Brake upgrade hoses...suggestions?
  105. OK, best price I've found on DS2500s is $190, on HPS is $125. I DO NOT want a pad that is
  106. brake upgrade questions: 996 vs. boxter
  107. Tools to remove caliper 93 90s
  108. Brake pads necessary?
  109. In responce to VR_Life's post on rear brakes..,
  110. Axxis Ultimate/Deluxe Plus ?
  111. Tips for changing brake lines?
  112. Is there a caliper rebuild kit for the Boxster 986 calipers?
  113. Hawk HPS with wear sensor install and review.
  114. do you lose ABS with stoptechs or ecs tuning's II kit? or any big brake for that matter?
  115. Poll: What Brake Pads are you currently using? How do you like them?
  116. Anyone have a handy site/list of various coefficients of friction of various brake pads?
  117. Can A6 2.7T brakes fit on a B6 A4?
  118. Good old post regarding brake bias (with lots of links in reply posts)
  119. StopTech - In need of a trademark attorney?
  120. Thanks to Luke@TireRack! Hawk HPS on the way, and somehow saved a few bucks off the website. NOICE!
  121. hypotetical idea: VW Touereg has huge meaty brakes
  122. Make your own power brake bleeder
  123. Anyone buy cross/drilled cadmium coated rotors from ECS? Any good?
  124. Starting to hunt for braking options---> need opinions
  125. Is it worth the extra $$ for Cadmium Plating? Looks wise that is?
  126. need pads, rotors?
  127. Does the Stoptech BBK work with 17" Avus, 17" piepan and 18" 9 spoke RS6 wheels on an 02 S6?
  128. Movit 4m6 BBK
  129. Stock Front C5 S6 Brakes
  130. B6 A4 upgrade to B7 brakes?
  131. Gonna try the new Brembo 345mm affordable kit on my B6 A4
  132. Repost: LAST CHANCE to get a Stoptech Big Brake Kit on sale!
  133. Braking g's Comparison (edit 6/23/05, 14 additions)
  134. silver stoptech cars lets see pixies.
  135. i wnat to do A8 / Boxster brake upgrade.....
  136. Help me decide...Hawk HP+ pads or Carbotech Panther Plus...
  137. Possible to convert non-floating rotor/hat to a floating combo?
  138. what could cause a clicking/clunky sound
  139. Bigger factory brakes for 99 A6 Avant?
  140. Need front rotors for a 2000 2.7t. Would like cross/drilled/slotted...
  141. Too many pads...too little solid info
  142. Those with Front BBK's : Opinions on rear upgrade ? APR/Stasis Track Sport rear, or ECS Stage1 rear
  143. Rotor testing...
  144. someone get me cheap stoptech rear slotted rotors with pads please! =)
  145. Yes we have brakes! Might as well start a compendium...
  146. Rotor replacement
  147. Me braking :-)...
  148. STaSIS Rear Brake Kit :-)...
  149. What is the best choice for aftermarket rotors for A6 2.7T
  150. Brakes?
  151. Lets get this straight,its brake,not break !!
  152. WTF?
  153. My breaks broke...
  154. hellooooo brakes forum!
  155. Welcome to the Brakes Forum
