View Full Version : Brakes Discussion
- Lifespan of Motul DOT 5.1 fluid vs RBF-600 for street use?
- Changing rear brake pads - how thin does the wrench need to be to remove the caliper?
- anyone experience alcon brake shudder at low speeds?
- Brake system exorcist needed!!!
- what is the best brake pad for 03 allroad
- Will 355mm rotors fit stg 4 ecs bbks which come with 352 rotors?
- Anyone know of a retail store that carries Zimmerman Rotors over the counter?
- A8 rotors and A4 Calipers on UrS4?
- '03 A4 Brakes
- Anyone had an AP Racing caliper rebuilt?
- One Man brake bleeder from Napa
- who else makes a ferro carbon pads besides hawk
- Ferodo DS2500 rule! got them for my alcons for 160$ and I love them
- *@&%$# Brake dust
- brake pads/rotors
- A4 pulls to the left when applying brakes
- EBC Brake Bad Wear Sensor Question
- Re-post from 90/80 forum..............
- Brake warning lamp A6
- Chaning Front Brake
- Sometimes ABS and Brake light-on 01203 -Electrical Connection between ABS and Instrument Cluster???
- Pagid pads for RS6?
- Need part number for brake pipe (left rear)....98 A4 QMS
- New Audi Brakes !!!
- just put new pads on my 97 a6 and it squeaks like crazy can some one help me i use ebc green pads
- this seems high to me: $700 to do fronts on my RS6 at the dealer!
- Matt Weiss at Stoptech rules..very helpful...always there..very knowledgeable...
- Brake booster question, stf didn't find a definative answer, kind of long
- ok, stfa. shall i burnish new rotors with old pads
- Dire Warning!!! - inspected my SS brake lines and found both front lines are failing...
- how does one tell if rotors need to be turned?
- Interesting NY Times article on ceramic brakes
- abs esp lights on
- Brake gurus: There's a debate going on in a 4runner forum, what are your thoughts on if
- Stoptech / 18 x 8.5 iForged Seneka
- Can anyone recommend a good brake pad upgrade for my 04 A6 4.2?
- Choice for pads? What do you think is the best choice for new pads for
- time for new brakes- what are some good options? 97 2.8qm
- Brake cooling kits. Anything exist for Audis?
- S8 Front Brakes
- changing ECS stg 4 rotors.Help needed
- Whos sells the TT front caliper brackets for less?
- Whats the going rate for a used Stoptech 332mm BBK?
- best brake squeal solution?........
- Failed Rotor Seasoning / Pad Bedding?
- Grinding brake noise at low speed, pads look fine
- Changing Rear Brake pads for 2002 A4 Avant Quatrro
- "hard" brake line questions
- Cleaning Motive Bleeder after use
- Need rear pads and possibly rotors
- Brake fluid incompatibility?
- where can I buy the Ferodo DS2500 pad for the alocn type b?
- front left brake pad is running out faster than the right brake pad
- Stupid Audi Dealer!
- Discuss: rotors > slotted v. drilled, frozen v. untreated?
- anyone tried the 2bennett brakes, i would like to upgrade my b7 brakes
- Stock OEM (Jurid) Pad question...
- if I want to decrease the amount of pedal movement after adding a BBK on a older a4
- STaSIS Engineering's new website is up and running, take a peek...
- I need some quiet brake pads...
- BLAUsport Orbital Slotted Brake Dics - Turning the rotors
- Will A4 B6 brakes fit into an A4 B5 (including caliper brakets and brake lines)?
- XPOST: Brembo BBK Fitment
- abs control module
- safety wire needed?
- Do I need to do anything to remove the gold plating stuff from new rotors?
- Anyone here recommend ATE Super Blue? I am also working a Frozen Rotor Group buy.
- ABS CONTROL MODULE
- Track brakes/pads/rotors for RS6.
- Brake upgrade for 19" wheel on 2002 A4, suggestions?
- NEED: Brakes and Rotors All Around
- Big thanks to Jason @ ECS....I finally have quiet brakes.....8^)
- BBK on B6 Quattro 3.0 with RS6 18x8.5 ET35
- Does a BBK fit under 18" Ultraleggeras on a B6 S4?
- Axxis Metal Masters normally fair/poor on initial bite in the rain?
- Doing my gf's brakes this weekend, 99 Civic EX, anything i should know?
- pic #3
- pic #2
- UPS dropped my new A8 rotors...can this still be used?
- B5 S4, used DOT3 instead of DOT4 brake fluid, cause for concern??
- what is the lowest dusting brake pads available for the B7
- ABS & ASR malfunctions - Need help!
- brakes lock up
- Blauparts.com A8 brake upgrade for A4?
- Stoptech or B6 S4 brakes ??????
- Brakes sticking on and sinking pedal..
- Recommendation for Pads - 02 A6 4.2
- what novice track pads are availible for the B7 a4 2.0t
- STFA, Edy Jun's. looking for wright ups on Mintex pads. Under hard driving conditions I have...
- 80: ABS Problem
- Stoptech noise issue
- Need insite on A4- A8 Brake Upgrade... please
- Need some questions answered...
- Should my metallic breaks be squealing?
- High perf. street brake pad advice for Boxster caliper fronts, stock rears
- caliper mounting dimensions?
- slotted or cross-drilled for a daily driver??
- Need to replace brake pads and possibly rotors on my '01 A4. Looking for input ...
- Question...Brakes acting up after brake fluid flush service
- Brake questions
- My Pagid pads came with 4 new bolts: Are those to replace the bolts..
- Bedding In procedure question: I am installing OEM type rotors and Pagid pads...
- Tech Session by Audi Club NW and Speedware
- (cross post from A4B5) Got my brake parts from www.germanauto.com...
- Does anyone know if ECS' 2-piece rotors are priced at $634.95 each or per-pair?
- Squeak from right front brake - I'm determined to eliminate it
- Where is the best source on how to change brake pads on 01A4
- 95 a6 upgrade
- Anyone know of an improved braking option for a C6 A6 ? (4.2)
- Does anyone have any experience/opinion about DiscItalia Rotors? (see link)
- Mintex "red box" pad's are they the way to go 95% Street & 5% track?
- ? on purchasing ECS 2 piece floating rotors B6 S4
- 2003 A6 Squealing Brakes
- a3 brake upgrade
- wheel clearance of B5S4 brakes vs Stoptech 332mm BBK
- Red Brake Light
- If just getting brake pads replaced, is "bed-in" procedure still recommended? TIA
- good place to get pagid or ferodo pads for a good price???
- What are the consensus of the best bang/buck SS lines for brakes?
- will boxster calipers fit b5 2.8q?
- How to Make Brake Pads
- Squeaky front brakes
- rotor/pad question..
- AP Racing or Stoptech? which one to get?
- When would one need to rebuild a caliper?
- S4 F/R Brakes in A4 2.8??
- What's a good price nowadays for Cayenne S brakes (front and rear) and...
- lots of pad, lots of fluid, brakes feel "wet" all the time (99 A4Q)
- NHC Kevlar Metalic Disk Vs. PBR (AXXIS) Brake Pads
- Need Brake Booster Line
- So I'm driving home tonight...
- Well this is fun...brake pad warning light is coming on with Stoptech 355mm kit
- nOOb question on brake pad sizing; how many different sizes are there?
- Brake pedal feels harder and theres a decrease in brake power
- Does anybody have any experience w/brake cooling ducting on a B5? Thanx.
- Cross post from the B5S5 forum...thought you guys may have some ideas....
- My ECS Stg 4s are starting to sqeal at low speed when applied, say 15mph below.....
- A4B6 larger rear brakes
- SS lines for daily commuter...yay or nay?
- Rotor question: is there a non-STaSIS alternative for 13" rotors to be used with Alcon calipers?
- URGENT: Will 17" OZ Chronos clear Stoptech 355 Kit?
- Cross post... HELP PLEASE
- HELP! anybody here have alcon btype calipers? i need to borrow a set of *very* hard pads for a day
- doing the rear brakes without the expensive special tool
- Wanted; new 993tt big blacks pair...
- brakes?
- Excessive brake wear? Would appreciate comments and
- Haven't checked yet..but did I do any major damage taking my Axxis Metalmasters one session on track
- poll: stoptech or ecs stage3?
- Where to buy AP Racing BBK's?
- X-post....caliper storage and powdercoating questions...
- part number for 993TT rotor ring
- Need some help..
- FS: Hawk HPS Pads for 993TT front calipers
- Are local shops who can make custom SS brake lines going to be
- Anyone know any other rotors besides stoptech that will fit Stoptech ST40 calipers?...
- Touareg Brakes...eem to be 6 piston like ECS Cayenne?...
- PSA - Performance Friction 01's Rock!
- Stoptech 332 or 355 with OEM 17'' rims for B6??
- ECS Stage 2 v2, pads hanging off rotor...
- Bought some HP EVO 18X8 rims for a c5 2.8. Do I need hub centric spacers or rings?
- X-Post - quick answer needed - rotors?
- Weekend Project: Brake Upgrade
- x-post from Wheels/Tires forum...regarding s8 avus and 355/328 stoptechs...
- rotors
- Dust Shield: Upgrading to front A8 rotors...
- Brake noises
- track pads for b5 s4.... opinions please.
- Anyone know what type of assembly paste to use when replacing the seal kit on a caliper?
- Front Calipers for an Allroad
- B5 Passat 4-Mot Wagon F/R balance ??
- anyone hear anything on Road Tuff brake pads?
- Where to have SS braided brake lines made?
- Any suggestions for c5 2.8 Rotors n Pads combo that offer the best price, performance and durability
- Lip/ridge at the outer edge of my rotors
- Got the stoptech's on this afternoon...bedding them tonight..
- faded the F out of the HPS over the weekend on mountain drive...
- rotors
- Need help!....996 Monoblock brake noise
- need brake pads and rotors...what do u recommend
- Anybody using/tried these?
- Carbotech Bobcats not suitable for one day track event?
- For Sale: Dymax Kevlar metallic front pads
- Prepping for 1st ACNA event: Ferodo, DBA on stock S4 (HP2) calipers?
- Brake options for BBS RS-GT? Please advise.
- A.W.E. Tuning at H2O International September 25th
- Slotted rotors, which way should slots face
- Vag scan came up with 01119 - Gear Recognition Signal
- anyone have a new porsche part connect? need 993 turbo s yellow caliper left side
- Lugnuts WAY too tight, was it just me? brake problem?
- 1993 audi 100 brake upgrade-advise please
- Rear S4 brakes on an A4
- Looking for some very good performance pads (front) that are Quiet for my ...
- Quest. about Porche brakes on S4!
- Are there 2 piece rotors for stock '00-S8 Brembo calipers?
- rotors as unsprung weight- a real concern?
- This just in..........................Jason at ECS Tuning is GREAT...and the company is GREAT.......
- rotor wear
- SS Brake Line Adaptor
- VERY uneven Porterfield pad wear at the track on my RS 6...
- Pagid, Hawk or Ferodo?
- brake rotors/pads
- A4 Pad and Rotor Q's
- Problem when hard braking..
- Power brake bleeders
- Squishy Brake Pedal After Brake Line Repair
- Those with the A8 rotors with Porsche Boxster calipers...
- Storing brake fluid question.
- Pedal Feel
- B6 S4 brake rotors and HPDE pads
- Free shipping on Stoptech and Stasis Alcon Brake Systems from Achtuning!!!
- R32 Brakes....
- If anyone has a BBK for sale please e-mail ASAP ! ! !
- X-post. Was suggested I post here as well....
- Pedal feel......
- Brake Pedal Sensitivity?
- Hawk HPS 411.....
- Suggestins on brakes
- Porterfeild's all the way! I have them on my bbk and some guys I know ...
- pad reccomendations? looked around, and swamped with info
- Hawk HPS pads. are they supposed to be noisy?
- Cross post from motorsports forum...
- Attn: Another Drew....... Alcon Type- B Hats
- Any options for rear brake upgrades?
- 1997 FWD A4 Rear Brake Service
- Aluminum brake hats -- any suggestions for a source?
- brake pads. dont care about dust one bit. i want good initial bite.
- Non dusting Brake pads
- Brake Pad comparo's.....(stop tech availability)
- Brake "Noise, Harshness, Vibration"
- how do i know if my brakes are running hot?
- Thoughts on ECS BIG brake kit?
- Big thanks to Jason @ ECS. Ordered my stg1 brakes last Thu & they're on my doorstep now, x-cty.
- A8 Upgrade | DIY question.
- Brake Bleed | How much fluid is needed?
- in the bentley manual, it menitions that rear caliper carriers come with the sliders and boots.
- 91 Audi 100 brakes drag
- Stoptech stage 1 brake upgrade for 3.2L TT ???
- Thanks to Jason at ECS Tuning for all the help over the last few days!!
- Can solid rear rotors on B5A4 be replaced by same-diameter vented rotors, or will the caliper not...
- powder coating calipers
- Need opinions please on New Pads and Rotors...Alcon 4 pot brakes
- Looking at track pads...
- Very worn out rotors except for the edges... how do i remove the caliper
- how much more bleeding is required if you remove a caliper/brake line?
- anybody ever rebuild the stock calipers?
- (X-post) Brake pads for my '04 2.7T S-line??...
- Best front kit for under a grand? ECS?
- Thinking about selling my ECS 2pc slotted rotors
