"Rubbing/ Creeking"sound from steering column
Old May 28, 2003 | 05:08 AM
smbaa6's Avatar
New Member
Default "Rubbing/ Creeking"sound from steering column
Sometimes while turning (>90 deg)I get a creeking/rubbing sound from the steering column. Sounds as if something needs oil/lubrication in the steering column.
Any ideas what it might be. Car runs straight.
SM
1998 A6 2.8Q w/ 77 K
Old May 28, 2003 | 06:56 AM
brianmski's Avatar
mine does that too. only on left turn though
Old May 28, 2003 | 07:36 AM
MP4.2+6.0's Avatar
Tech Guru
Default Spiral Spring ?
Try the spiral spring that connects the steering wheel controls and airbag behind the steering wheel. Typically replaced rather than lubricated. Don't fool with it if you aren't familiar w/ working w/ airbag assemblies since you would need to remove the steering wheel first.
Old May 28, 2003 | 10:18 AM
smbaa6's Avatar
New Member
Any problem if I ignore It
Old May 28, 2003 | 12:59 PM
CEB's Avatar
CEB
Default nope - have them....
...look at it at the next service (assuming it is still under warranty). Both of mine (my old A6 and my S6) gave off a little, barely audible creak on some turns.....
Old May 28, 2003 | 08:13 PM
grandpamike's Avatar
Default Re: "Rubbing/ Creeking"sound from steering column
Take it to the dealer. Had the same noise, and they are replacing the steering column. I have a 2001 2.7T.
Terry
Dec 1, 2020 01:52 PM
Leggs
A6 (C8 Platform) Discussion
Jul 4, 2019 01:43 PM
oc63rag
Feb 27, 2008 09:18 PM
Tar Heel S4
Mar 28, 2002 11:52 AM
Tom S
Dec 10, 1999 11:22 PM
