What's the size of our rear license plate light bulbs? Mine burnt out.
..might have been a voltage spike.
Which one of these <a href="http://store.42draftdesigns.com/Fuse-Style-LEDs_c_39-1.html">LED replacements</a> would work? The 39mm or the 42mm? I know they are the fuse style bulbs.
I used this <a href="https://forums.audiworld.com/tt/threads/455952.phtml#1805588">post</a> as a reference...<ul><li><a href="https://forums.audiworld.com/tt/msgs/1730247.phtml">FAQ help</a></li></ul>
If you find the cheap crappy plastic clip on the housing is cracked then take a look at the URL link. If it isn't cracked yet, it will be soon. I used RTV silicone to strengthen the clip and that seems to work well as an alternative to buying a replacement from the stealership.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1805581.phtml">https://forums.audiworld.com/tt/msgs/1805581.phtml</a</li></ul>
