Help me out with my mirror problem
Old Jul 23, 2004 | 12:22 PM
Derek@UI's Avatar
Default Help me out with my mirror problem
well i bought a compass, auto dim.. and i went to the dealer to install it.. they hooked it.. tried a bunch of stuff.. they dont kno how to get it to power on..
has anyone done this that might know how to help me out? is there some kinda hack into sunroof wires?
they said they want to charge me a $400 tech to diag what to do to get it to work.. im not paying that and id bet non of you would either.. what can i do to get it to work? whos done this mod/upgrade before in a 2004?
Old Jul 24, 2004 | 06:08 PM
alpha helix's Avatar
New Member
Default Re: Help me out with my mirror problem
I added this mod to my '03, the wiring harness exists from the connector station under the lower left A pillar kick panel. I had to add a jumper from a fused/switched source at the fuse panel to power the mirror harness connection in the roof.
The connector at the source end of the harness is a 17 position harness connector, the mating half of that connector does not have the power supply wire terminal in it. I used a computer hard drive cable connector pin, soldered a wire to it and inserted it into the empty connector half at the same terminal position. That wire applied switched +12 volts to the terminal in the roof harness half of the 17 pin harness connector pair.
On the '03 wiring diagram: You need to power the black/blue wire at T17f/3, that's the ORANGE 17 position harness connector, terminal position THREE, at the connector station under the left kick panel. ("T17f - 17-Pin Connector, orange, connector station A-pillar, left.") The mirror circuit ground is already connected via the roof harness.
The other connections on the diagram go to the left and right door controllers, to the reverse switch and the overhead interior light.
I did not connect any of the these other circuits. The mirror works fine with just the power connected.
Old Jul 24, 2004 | 09:14 PM
Derek@UI's Avatar
im sorry thats a little to complicated for me.. is there a moron version?
Old Jul 28, 2004 | 08:57 PM
New Member
Default Re: im sorry thats a little to complicated for me.. is there a moron version?
Maybe you can print the info and provide it to your dealer so that they can do it for you for lots less than they wanted before.
IHTH
Old Apr 14, 2007 | 12:23 AM
FoKai's Avatar
Default yes there is a hack into the overhead interior lights...
i used one of those radio shack flat blade type clips that slide into those blades things for power
Raiden256
A6 (C7 Platform) Discussion
28
Dec 10, 2015 02:50 AM
OneOfOne
Audi A3 / S3 / RS 3 MKII
9
Nov 10, 2015 06:22 PM
ECS Tuning-Audi
Sep 10, 2015 01:14 PM
ECS Tuning-Audi
Sep 10, 2015 12:39 PM
Ford576
Sep 10, 2015 12:38 PM
