g0t trifceta?? stereo help
Old Jul 24, 2004 | 08:58 PM
Skibum the Original's Avatar
Default g0t trifceta?? stereo help
Anyone able to draw a wiring diagram for how to run 3 dvc subs from 1 amp?
Old Jul 25, 2004 | 08:34 AM
bbaudi382's Avatar
what ohm are the coils on each sub
Old Jul 25, 2004 | 09:03 AM
well i havent bought em yet. Do i need 6 ohm subs?
Old Jul 25, 2004 | 02:46 PM
bbaudi382's Avatar
Default not necessarily.
if you are set on running 3 subs, you could get 3 6ohm dual voice coil sub and wire it up to run at 1 ohm or 4 ohms...
you can run other impedances as well but you would have to be more careful with headroom because of the less perfect impedances...but it wouldnt be a problem if you have the amps set up correctly.
Old Jun 20, 2021 | 07:26 PM
1stRS's Avatar
Because I like to tinker- I cut the tabs off and hooked up the positive on one side and the negative on the other. Sounds nearly the same, quite possibly a little tiny bit better. Still not what I wanted. I’m going to reinstall stock tomorrow and head to a shop sometime in the near future.
clip playing g XM Chill station, so it might get pulled from YouTube.
T1no33
Audi A3 / S3 / RS 3 MKII
14
Feb 9, 2019 01:55 PM
Bruce B
Q5/SQ5 MKI (8R) Discussion
Sep 25, 2015 12:11 AM
kylejhorner
Audi A3 / S3 / RS 3
Sep 18, 2015 10:27 AM
SWelsch
Sep 16, 2015 10:21 AM
chubs636
Sep 14, 2015 03:42 PM
