B7 Brake Warranty from today's AW Front Page....in plain english.
Old Mar 14, 2005 | 05:37 AM
user 46462's Avatar
Banned
Default B7 Brake Warranty from today's AW Front Page....in plain english.
Warranty and Maintenance
Brakes, wipers and other normal wear and tear items now carry a basic warranty of 6 months for comfort problems (i.e. wiper chatter, brake shimmy, etc.). Brakes can be replaced once during the 4 yr/50,000 mile warranty period if they are worn out, however the warranty will no longer cover rotors that are damaged from metal to metal contact. We see a real positive in the fact that brakes on the B7's can be replaced prior to reaching the minimum standard. Pads can now be replaced if they have less than 5mm of friction material, and rotors can be replaced if they are within 0.5mm larger than the minimum specification for that rotor. This is being done to allow a technician to replace brakes that are close to wearing out, but have not reached the minimum specification. As a result the customer should not have brakes wearing out in-between services.
Brakes will still be covered after 6-months for material and workmanship (cracked pads for example). For the enthusiast crowd it is critical to thoroughly read the user manual and totally understand what is and is not covered in order to avoid surprises. Problems that could be caused by competitive events (racing or time trials), improper use of brakes (riding the brakes rather than using lower gears) will be looked at closely and possibly rejected by the warranty system unless the work meets certain failure guidelines.
Old Mar 14, 2005 | 05:57 AM
Matt Devo's Avatar
sounds reasonable to me, other than the ambiguity of determining improper use
Old Mar 14, 2005 | 12:47 PM
Silver Streakin''s Avatar
Member
Default sorry, people like me ruined it for everyone else.
my 2nd set of rear pads after the Glen:
<img src="http://pictureposter.audiworld.com/10901/dscn1104.jpg">
I lost count on the number of pads and rotors that were done under warranty when I was track noob.
I have Stoptechs now and use track pads all around for track/race days.
Old Mar 14, 2005 | 05:49 PM
Bob Petruska's Avatar
25 Year Member
What are other normal wear and tear items...that statement scares me!
N'Syncro
33
Feb 16, 2020 03:12 PM
ebod0000
A6 (C7 Platform) Discussion
170
Jun 7, 2018 01:39 PM
LaserSVT
64
Jan 19, 2016 04:26 PM
C6Silver
Q7 MK 1 Discussion
Sep 1, 2015 08:46 PM
zhaoweitian
A7
Sep 1, 2015 03:15 PM
