Transfer Case Leak
There is a leak on my '04 with 85k miles in the transmission. I've been told it's the transfer case output seal and that it's deep within the transmission. I've been told this is not serviceable and there are no parts made available for a fix. The trans works fine, but for this leak which makes it's way to the passenger side exhaust and creates an odor. Gear oil was topped and underside cleaned... I've been told it time for a tranny. (Indy & Audi Dealer)
It's a shame -- the tranny performs fine.
Has anyone seen or heard of this issue?
Best route? (Reman/used/etc)
A transfer case output shaft seal inside the tranny is leaking gear oil down through the inspection port onto the cat on the passenger side.
Audi has no material on repairing this issue. (i.e. replace trans)
Has anyone had this issue or any experience as it's a shame that the tranny is performing flawlessly, but for this leak.
As it stands right now I am left with two options... replace trans or have the gear oil topped every so often and deal with the smell.
2. Overlapping the D2 and C5 4.2, try to contact a guy whose signature/handle is TozoM8. Seriously knowledgable on the D2/C5 4.2 5HP24A unit. Based in the Chicago area. Rebuilds and repairs trannies too. As I recall, he actually posted either on this board or the Quattroworld board in response to some post very recently.
3. Try calling a ZF distributor for real experience and advice. A half dozen years ago these guys were few in number and kind of specialized aound the U.S. by car manufacturer (Audi, BMW, Jag, etc.), but now less so and more numerous.You need the Audi ones too, because (at least until recently) pretty much just Audi used the "A" variants of the trannies involved that signified AWD (as opposed to traditional RWD like BMW and Jag sedans). Eriksson in Connecticut was the one which in the "old" system seemed to lead on Audi's. I talked to them about my C5 4.2 and also had them rebuild my valve body. Peter Schmid (the name of the guy and the business) is the guy here by me in the Bay Area that seems to be the "go to" local source these days. See attached link for full list and contact info: http://www.zf.com/na/content/media/u...rs/PC_dist.pdf
4. If you confirm it is inaccessible w/out a tranny R&R--as in I bet you will be at least $2500+ just to deal w/ seal (OUCH!)--consider other practical fixes/compromises. One I have heard NOT to do is plug up the weep port with sealant; that can force the fluid out elsewhere or with other bad results (like blowing a seal between gear oil and tranny fluid elsewhere, which woud be a meltdown scenario). Instead, to eliminate smell but still have the leak, maybe you could fashion some kind of drip piece of sorts out of sheet metal and attach it somehow so the fluid doesn't hit the exhaust pipe on its way down. Or, look into gear seal sealants--in the "old days" I remember these existing oriented toward differentials and manual gear boxes. Since the part of the tranny you are dealing with is lubricated with gear oil to start with, maybe you can find a solution there. And worst case, its a fail and you have to take tranny out eventually anyway. I wouldn't be that casual with the internal ATF guts of the tranny, but the diff units are really just basic gear lubrication stuff. You could search on line, ask the ZF guys for practical ideas, and or get to an old line parts shop with career car guys who would know the available products--probably ones that either have solids in them that seal leaks, or ones that swell seals somewhat. A variant of the same stuff used to try to seal up leaking front and rear main (crank) motor seals.
If I exhausted my other options and tried to get a better idea from the ZF experts, the seal fix type additives in the end is what I would likely try myself as a "not much to lose" anyway choice.
The only one with "inside leak" of gear oil I can see is one on the left side output of the front differential. I am not sure but that seal can be changed from inside the differential casing and that can be done without removing transmission. Just drive shafts off, differential out and there is that seal. As a matter of fact, looking at Q7 transmission I would say that's the only way it can be changed.
At least through the C5/D2 era Audi's came with a separate sticker underhood (red and silver in color, where you/the dealer was supposed to write in the service mileage; sold still by ECS as a piece part) specifically admonishing to check the front diff unit separately since apparently many didn't understand gear oil had to go into the tranny in two completely separate areas of the overall case. A TSB was issued on the need to check the fluid separately (with the stickers) way back in the C4/D1 era. Having owned a C4, I remember back to that timeframe--the earlier quattro's were all sticks and used a multi hollow tube power transmission back up to the front diff that couldn't be replicated with a torque converter in between; that necessitated the separate power take off side unit stuff and presumably the dual gear oil (and presumably more seals) result that finally enabled them to offer quattro in a slushbox.
