Transmission rebuild?
Old Aug 4, 2016 | 08:37 AM
The2001TTguy's Avatar
Default Transmission rebuild?
1st and 2nd gear are dead on my 2001 TT 225hp Quattro 6-speed.
I'm trying to figure out the best way to get this fixed. I'm not having much luck finding local repair shops that will rebuild a manual transmission for an Audi because it requires vendor specific tools that nobody wants to buy given the low volume of work they'd actually do.
One place quoted me $1300 for a used transmission with 100,000 miles on it.
Anyone got any ideas for me on how to do about this, what my options are, etc?
Old Aug 4, 2016 | 09:35 AM
LarryJa's Avatar
I'd probably go for a used trans &, then, tear into the original. I'd want to see if it was a shifter issue, or gears/shaft/bearings problem. If it was a shifter/forks kinda issue, I'd try to fix it & put it up on a shelf for future reinstallation.
But, that's me.
Old Aug 6, 2016 | 01:44 PM
Mister Bally's Avatar
This sounds like the shifter fork deal. Trans out but a somewhat easy job.
I had a dealer R&R my Beetle (same basic drivetrain) transmission five years ago to replace 1st gear that Ballykid ground to bits being, well, himself. Also had the three main clutch pieces replaced with OEM parts. $2000.00 parts & labor. There was a gear & Synchro included in the part cost.
Old Aug 10, 2016 | 08:13 AM
Default Fix
Someone on another forum pointed out this:
Hope this works!
Old Aug 10, 2016 | 09:46 AM
Default Tv episode
Here's the wheeler dealers episode that shows fixing this problem:
Originally Posted by TTops
Here ya go. (you may need to scroll down a little ways to get to the start screen) Good luck with the fix!
Series 11 Episode 10 - Wheeler Dealers Episodes
Dave-2001
Aug 23, 2015 03:35 PM
ensanorth
10
May 11, 2007 08:09 AM
kofoured1.8
Jan 6, 2007 05:46 AM
bcr84urq
Nov 9, 2006 12:40 PM
Nojoi|Antisaint
Aug 29, 2004 11:48 AM
