A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
low pressure fuel pump prime function
Old Mar 17, 2019 | 05:06 PM
wotseurba's Avatar
Default low pressure fuel pump prime function
I've search this forum, and multiple other venues and am unable to definitively find out:
Does this platform use the low pressure in-tank pump to prime the fuel system by either driver door open, or turn key to on, or both?
Currently this car does neither, and suffers from a 3 - 5 second cranking time before starting. The in-tank pump functions well, and tests well and shows good pressure when the engine is running using VCDS,
This is a 2006 B7, 3.2 FSI
Edit: should note that this car never had this long crank starting issue before, and if re-starting within an hour it starts up instantly.
TheDroid
May 16, 2011 05:59 AM
Noob_A4_Life
12
Jul 11, 2007 04:27 AM
A4wheelin
10
Feb 20, 2007 09:17 AM
Nige_UK
VAG-COM Discussion
Jun 29, 2003 05:52 PM
