Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
ZA: Central Locking issue? 2009 q7
Old Jan 12, 2025 | 08:37 PM
MarbroZa's Avatar
Default ZA: Central Locking issue? 2009 q7
Morning Gents, and ladies
My Q7 has started giving me a strange problem. The car locks fine, But the drivers door doesnt unlock.
I can unlock it by pulling the handle from inside,
It did have a issue before, where it would skip the unlock now and then, But you lock and then unlock again and it works..
Anyone got suggestions on what I can check, and what I might need to replace?
Its only the drivers door
Old Jan 12, 2025 | 09:16 PM
MarbroZa's Avatar
Found a few sites,
Few solutions, including looking under a rubber grommet for a plastic adjuster. Similar to child lock? But the drivers door doesnt have one
Then , I found this
https://www.vwaudiforum.co.uk/forum/...62#post1039362
And it suggested ,
  • Pull the outside and inside handle at the same time until you feel it click: This appeared to work for a while, but failed again.
Tried this a few times, Low and behold, it unlocks again! so something must be gunked up in there.
Other solutions,
Drill into the actuator and spray WD40,
Replace the actuator.
Replace the door
So, for now, the handle tugging will work
Old Jan 13, 2025 | 09:57 AM
-Wes-'s Avatar
I suspect it is probably just getting gummed up. You'd have to access the actuator to do anything about it, so at that point it is just a choice of repair or replace.
Old Jan 13, 2025 | 05:16 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
FWIW:
Be sure to diagnostic scan your car fully (never a bad idea anyway) if you have the door handles with the external locking buttons built into them, as the proximity sensors embedded within those specific type handles and the dedicated external locking button eventually ground out and cause problems.
Old Jan 13, 2025 | 08:18 PM
MarbroZa's Avatar
yeah that fix was hella temp... it stopped working like 2 unlocks later..
Going to pull it apart this weekend and see, if its just a clean, maybe i win
@'10Q7TDI_Prestige' , Its the 2009, I dont even have fancy bluetooth, so no proxy sensors. its jsut the actuator.
syoung09
Apr 20, 2014 05:08 PM
A8L 2000 Ohio
Mar 2, 2007 05:37 AM
mpwolf
Jun 22, 2002 09:34 PM
Stoney
May 4, 2002 08:07 PM
