Adding Nav to an 06 A6 (MMI) - Can I use the Sat Radio MOST?
After doing some research and talking to AudiUSA, the CSR gave me 2 part numbers. One is for the DVD player, and one is a 'retrofit kit', essentially a wiring harness from what I can tell.
A quick glance in the trunk revealed a pair of fiber optic cables, what I believe is the MOST connection for the satellite radio.
If I don't intend on adding sat radio, can I use this hookup? Or will I need additional plugs that only the retrofit harness provides?
I ask because I just read a post where someone added a TV tuner and used the MOST cables usually reserved for the satellite module.
Thanks!
-Jim
Thanks!
-Jim
Re: Adding Nav to an 06 A6 (MMI) - Can I use the Sat Radio MOST?
yes, no problem. I just did it and it works fine. The fiber optics line is a loop, and as long are you are in the loop, it should work.
SED8R
12-11-2018 05:03 PM
odoboyusa
02-28-2013 06:40 PM
jeffry
03-28-2011 04:24 PM
chicken1
05-11-2009 02:17 PM
